Can you setup incoming caller id on an MGCP enabled gateway with an FXO port?
Leo Ruelas
Can you setup incoming caller ID on an MGCP enabled gateway with an FXO port?
Not sure if this is possible. The gateway is a Cisco 2811 version 12.4.
Cisco Unified CM Administration System version: 8.6.2.22900-9
R0g22
Are your FXO lines subscribed for caller id ? Add "mgcp persistent offhook" command and the following as well -
voice-port x/y/z
timing guard-out 1000
shut
no shut
no mgcp
mgcp
