Cannot access web GUI on 8845
cainram
I'm getting conflicting information on how to access the Web GUI on this phone. Some say it's on by default and others say it's off. I can ping the phone but I get nothing when trying to access via http. I need to configure this phone for use with FusionPBX and have no access to Cisco Unified Communications Manager. factory reset the phone and updated to sip8845_65.12-6-1-0001-668 via TFTP. Any help would be greatly appreciated!
Jaime Valencia
You're running the Enterprise FW, so even if you have the GUI, it's NOT a configuration GUI, it's a read-only GUI.
You'd need to configure the device via the .xml config files for anything you want to do with it. Plenty of threads on CSC to use as reference.
If you wanted a phone with a config GUI, you had to buy the 3PCC variant of the device, or follow the procedure on upgrade.cisco.com to switch the FW version from Enterprise to 3PCC, and there might be an associated cost.
java
if this helps, please rate
Jaime Valencia
java
I have the same issue as well
To update the xml config files for the cisco 8845 ip phone is this done via SSH (PUTTY) and if so what would be the default user name and password...  I have seen several threads that say it is Cisco/Cisco or cisco/cisco but this is not working for me is there a different user and password for the ssh? Any help would be appreciated!
