07-09-2013 09:52 AM - edited 03-16-2019 06:17 PM
I have a few phones, all models 7962, that are not able to answer an incoming call or make an outgoing call by simply picking up the receiver. If the users press the line softkey they CAN answer an incoming call or make an outgoing call. Any ideas on where to start??
07-09-2013 09:54 AM
BTW, I have checked the spring in the receiver and the receiver is completely depressing the switch when put back in the cradle.
07-09-2013 11:52 AM
I'd still think the problem is the hookswitch, change the phone and see if that clears the issue.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
07-09-2013 12:03 PM
We have actually changed the phone twice already. Sorry, for not mentioning that.
07-10-2013 03:48 AM
i have seen this in older Firmware without wanting to quote TAC- maybe upgrade if it is "old"
07-10-2013 05:00 AM
Hi Derrick.
Which version of CUCM/CUCME are you running?
In case of CUCM, did apply a common phone profile?
Let me know.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
07-10-2013 10:01 AM
Is Auto Line Select enabled on the phone? If not what happens if you enable it?
Please remember to rate helpful responses and identify helpful or correct answers.
07-10-2013 11:33 AM
Interesting! How about a TAC case if none of the suggestions help.
Tapan
