Cannot Complete conference : Join /Select Buttons
savio.ibrahim
We have a 2801 ISR acting as a VG, router and CME.
We have CME version 8 with IOS c2801-spservicesk9-mz.151-1.T.bin
Whenever we press on "JOIN" , cannot complete conference messge is displayed.
We have only 1 DSP dedicated for active calls, so we're using a software based conferencing.
I already read many discussions in this forum but I'm suspicous about the possibility of "Join" and "Select" in software based ad-hoc conferencing.
we have 4 FXO ports connected to a SIMBOX. I already tried different configurations and options but still with the same result.
I'll post the configuration later when I got a confirmation regarding the possibility to do a 3 party conference in this case.
Jaime Valencia
This is explained in CME config guide:
Ad hoc conferences can be hardware-based or  software-based. Software-based conferences use the router CPU to provide  audio mixing (G.711) and are limited to 3 parties. Hardware-based  multi-party ad hoc conferencing uses digital signal processors (DSPs) to  allow more parties than software-based ad hoc conferencing and also  provides additional features such as Join and Conference Participant  List (ConfList).
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
It means that join and conflist cannot work in software based ad-hoc conferencing. But how could we could have a conference call or have more than 2 calls in the same conference while "JOIN" softkey can't work with software based ad-hoc ?
Do we use only "Confr" softkey for each call ?
I already configured maximum conference under Telephony service and assigned the required ephone-dn octile to the the ephone. But do I need to create additional free ephone-dns with ad-hoc conference , no huntstop ?
