08-11-2011 10:12 AM - edited 03-16-2019 06:26 AM
I have a script setup for a Unity AA that has the user press 1, 2 or 3 to be transferred to various departments. One department has a 7-digit local phone number, and the AA can successfully dial out to contact that department. Another department has a 10-digit toll-free number, however the AA does not dial out to contact that department for external callers -- the AA just hangs, evenutally giving a fast-busy signal after 30 seconds. If an internal caller enters the AA by dialing the call-in number, it will dial out.
I tested this with attempts to transfer to local numbers, long-distance numbers, and toll-free numbers -- local numbers are the only that transfer for outside callers. I added the allowExternalTransfers = True parameter, however that didn't help. I also tried having the AA redirect callers to an internal extension that had call-forwarding (All) configured to dial out, however that also didn't work.
Does anyone have some suggestions on how to get an AA to dial out to a non-local number?
- Unity Express: Version 3.2
- Call Manager Express: Version 7.0(0)
- Cisco IOS Software, 2800 Software, Version 12.4(20)T
Thanks!
Brian
Message was edited by: Brian Hoops -- Added attachment -- CME configuration
08-11-2011 10:42 AM
Hi Brian.
Try to post your CME conf. Once I had a similar issue and i solved with a translation rule on my cme.
Let me know.
Carlo
08-11-2011 11:25 AM
I attached the configuration to this discussion as a .txt document. Thanks!
08-11-2011 03:30 PM
Hi Brian.
Try to add direct-inward-dial to your pots dial-peer matching 10 digit toll-free number. For me it worked.
Please try it and let me know.
Carlo
08-12-2011 06:55 AM
Thanks for your response. I added direct-inward-dial to dial-peers 4, 12, and 19, however the same issue persists.
Do you have any other ideas?
08-12-2011 07:14 AM
Hi Brian.
Please post the output of a debug voip dialpeer inout during the rediretcion.
LMK
Carlo
08-12-2011 08:30 AM
The output is below. This is me dialing out from 6088777412 into our main line 8733379. At the greeting, I attempt the transfer to 18887450708.
Thanks.
Cisco2821#sh log
Syslog logging: enabled (0 messages dropped, 32075 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 559336 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 959 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
Trap logging: level errors, 456871 message lines logged
Logging to 10.35.1.8 (udp port 514, audit disabled,
authentication disabled, encryption disabled, link up),
456871 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Log Buffer (32768 bytes):
Info Type=DIALPEER_INFO_SPEECH
Aug 12 15:23:28.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=6088777412
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Aug 12 15:23:28.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Calling Number=, Called Number=379, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=379
Result=Success(0) after DP_MATCH_DEST
Aug 12 15:23:28.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20032
Calling Number=, Called Number=110, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=110
Aug 12 15:23:28.935: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.935: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20002
Calling Number=, Called Number=118, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=118
Result=SUCCESS(0)
1: Dial-peer Tag=20010
Calling Number=, Called Number=111, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=111
Result=SUCCESS(0)
1: Dial-peer Tag=20003
Calling Number=, Called Number=156, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=156
Result=SUCCESS(0)
1: Dial-peer Tag=20035
Calling Number=, Called Number=157, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=157
Result=SUCCESS(0)
1: Dial-peer Tag=20036
Result=SUCCESS(0)
Aug 12 15:23:28.935: //-1/DD7896E88C5E/DPM/dpMatchPeersCore:
Aug 12 15:23:28.935: //-1/DD7896E88C5E/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:28.939: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.939: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:28.939: //-1/DD7933108C61/DPM/dpMatchPeersCore:
Aug 12 15:23:28.939: //-1/DD7933108C61/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Result=SUCCESS(0)
Aug 12 15:23:28.943: //-1/DD7933108C64/DPM/dpMatchPeersCore:
Aug 12 15:23:28.943: //-1/DD7933108C64/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:28.943: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.943: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:28.943: //-1/DD79CF388C67/DPM/dpMatchPeersCore:
Aug 12 15:23:28.943: //-1/DD79CF388C67/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:28.947: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.947: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:28.947: //-1/DD7A6B608C6A/DPM/dpMatchPeersCore:
Aug 12 15:23:28.947: //-1/DD7A6B608C6A/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:28.955: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=6088777412, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 12 15:23:28.955: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Aug 12 15:23:28.959: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.959: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Result=NO_MATCH(-1)
Aug 12 15:23:28.963: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.963: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Aug 12 10:23:28.979: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 6088777412 N/A
Aug 12 15:23:28.987: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.991: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:28.991: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
Result=NO_MATCH(-1)
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Aug 12 15:23:29.003: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:29.007: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:29.007: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Calling Number=, Called Number=98733379, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=98733379
Result=SUCCESS(0)
1: Dial-peer Tag=3
2: Dial-peer Tag=11
3: Dial-peer Tag=18
Aug 12 10:23:29.115: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 6088777412 N/A
Aug 12 10:23:29.115: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 8733379 N/A
Aug 12 15:23:29.119: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:29.119: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=SUCCESS(0)
1: Dial-peer Tag=3
2: Dial-peer Tag=11
3: Dial-peer Tag=18
Aug 12 10:23:35.115: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 8733379 N/A
Aug 12 10:23:58.992: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DD7896E8C42D11E08C5E98DAB151FC9B, SetupTime 10:23:28.962 CDT Fri Aug 12 2011, PeerAddress 110, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 10:23:58.992 CDT Fri Aug 12 2011, DisconnectTime 10:23:58.992 CDT Fri Aug 12 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 12 10:23:58.992: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/12/2011 10:23:28.939,cgn:6088777412,cdn:110,frs:0,fid:421564,fcid:DD7896E8C42D11E08C5E98DAB151FC9B,legID:2EFCD,bguid:DD7896E8C42D11E08C5E98DAB151FC9B
Aug 12 15:23:58.996: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:58.996: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
Result=NO_MATCH(-1)
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Aug 12 10:23:59.016: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DD793310C42D11E08C6198DAB151FC9B, SetupTime 10:23:28.966 CDT Fri Aug 12 2011, PeerAddress 118, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 10:23:59.006 CDT Fri Aug 12 2011, DisconnectTime 10:23:59.006 CDT Fri Aug 12 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 12 10:23:59.016: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/12/2011 10:23:28.939,cgn:6088777412,cdn:118,frs:0,fid:421565,fcid:DD793310C42D11E08C6198DAB151FC9B,legID:2EFCE,bguid:DD793310C42D11E08C6198DAB151FC9B
Aug 12 15:23:59.024: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:59.024: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
Result=NO_MATCH(-1)
Aug 12 15:23:59.028: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:59.028: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Aug 12 10:23:59.040: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DD793310C42D11E08C6498DAB151FC9B, SetupTime 10:23:28.970 CDT Fri Aug 12 2011, PeerAddress 111, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 10:23:59.040 CDT Fri Aug 12 2011, DisconnectTime 10:23:59.040 CDT Fri Aug 12 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 12 15:23:59.048: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:59.048: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
Aug 12 15:23:59.052: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:59.052: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Aug 12 15:23:59.060: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=610, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=610
Aug 12 15:23:59.060: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=610
Result=SUCCESS(0)
Aug 12 15:23:59.060: //-1/DD66E3FF93E0/DPM/dpMatchPeersCore:
Aug 12 15:23:59.064: //-1/DD66E3FF93E0/DPM/dpMatchPeersCore:
Aug 12 15:23:59.064: //-1/DD66E3FF93E0/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Aug 12 15:23:59.100: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:59.100: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Aug 12 15:23:59.124: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:59.124: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Aug 12 15:23:59.128: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:23:59.128: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Result=SUCCESS(0)
Aug 12 15:24:05.848: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:24:05.848: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Calling Number=, Called Number=918887450708, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=918887450708
Result=SUCCESS(0)
1: Dial-peer Tag=4
2: Dial-peer Tag=12
3: Dial-peer Tag=19
Aug 12 15:24:05.848: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=4
2: Dial-peer Tag=12
3: Dial-peer Tag=19
Aug 12 15:24:05.852: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 12 15:24:05.852: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
Aug 12 15:24:05.852: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=4
2: Dial-peer Tag=12
3: Dial-peer Tag=19
Aug 12 15:24:05.852: //-1/DD66E3FF93E0/DPM/dpMatchPeersCore:
Aug 12 15:24:05.852: //-1/DD66E3FF93E0/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=4
2: Dial-peer Tag=12
3: Dial-peer Tag=19
Aug 12 10:24:05.968: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DD66E3FFC42D11E093E0001D709F07A0, SetupTime 10:24:05.968 CDT Fri Aug 12 2011, PeerAddress 918887450708, PeerSubAddress , DisconnectCause 1C , DisconnectText invalid number (28), ConnectTime 10:24:05.968 CDT Fri Aug 12 2011, DisconnectTime 10:24:05.968 CDT Fri Aug 12 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 12 10:24:05.968: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/12/2011 10:24:05.852,cgn:6088733379,cdn:918887450708,frs:0,fid:421578,fcid:DD66E3FFC42D11E093E0001D709F07A0,legID:2EFD3,bguid:DD66E3FFC42D11E093E0001D709F07A0
Aug 12 10:24:15.980: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DD66E3FFC42D11E093E0001D709F07A0, SetupTime 10:24:05.980 CDT Fri Aug 12 2011, PeerAddress 918887450708, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 10:24:15.980 CDT Fri Aug 12 2011, DisconnectTime 10:24:15.980 CDT Fri Aug 12 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 12 10:24:15.980: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/12/2011 10:24:05.976,cgn:6088777412,cdn:918887450708,frs:0,fid:421579,fcid:DD66E3FFC42D11E093E0001D709F07A0,legID:2EFD4,bguid:DD66E3FFC42D11E093E0001D709F07A0
Aug 12 10:24:20.488: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DC722307C42D11E08C5098DAB151FC9B, SetupTime 10:23:27.218 CDT Fri Aug 12 2011, PeerAddress 112, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 10:23:29.118 CDT Fri Aug 12 2011, DisconnectTime 10:24:20.478 CDT Fri Aug 12 2011, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 2553, ReceiveBytes 408480
Aug 12 10:24:20.488: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/12/2011 10:23:27.215,cgn:112,cdn:,frs:0,fid:421550,fcid:DC722307C42D11E08C5098DAB151FC9B,legID:2EFC8,bguid:DC722307C42D11E08C5098DAB151FC9B
Aug 12 10:24:20.500: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22 disconnected from 8733379 , call lasted 51 seconds
Aug 12 10:24:20.564: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DC722307C42D11E08C5098DAB151FC9B, SetupTime 10:23:28.514 CDT Fri Aug 12 2011, PeerAddress 98733379, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 10:23:29.114 CDT Fri Aug 12 2011, DisconnectTime 10:24:20.564 CDT Fri Aug 12 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 2553, TransmitBytes 428904, ReceivePackets 2573, ReceiveBytes 411680
Aug 12 10:24:20.564: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/12/2011 10:23:28.371,cgn:6088777412,cdn:98733379,frs:0,fid:421551,fcid:DC722307C42D11E08C5098DAB151FC9B,legID:2EFC9,bguid:DC722307C42D11E08C5098DAB151FC9B
08-14-2011 02:51 AM
Hi Brian.
Thanks for the output.
Try to add the following dialpeer to your config, and please post the output of debug isdn q931 and a show voice call status
dial-peer voice 23 pots
description ** Test Redirect dial-peer **
destination-pattern 918887450708
direct-inward-dial
port 0/0/0:23
forward-digits 11
Carlo
08-14-2011 11:21 AM
Carlo, Thanks again for the response. After adding the dial-peer, the result was the same.
debug isdn q931 output is as follows:
Cisco2821#
Cisco2821#sh log
Syslog logging: enabled (0 messages dropped, 32468 messages rate-limited,
Console logging: level debugging, 592078 messages logged, xml disabled,
filtering disabled
filtering disabled
Buffer logging: level debugging, 33701 messages logged, xml disabled,
filtering disabled
filtering disabled
Aug 14 18:16:48.370: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0DBB
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A10F02013C06072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02013C06072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 60
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '6087707050'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '8733379'
Plan:ISDN, Type:Subscriber(local)
Aug 14 18:16:48.370: ISDN Se0/0/0:23 Q931: Received SETUP callref = 0x8DBB callID = 0x5421 switch = primary-ni interface = User
Aug 14 18:16:48.390: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8DBB
Aug 14 18:16:48.414: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x0DBB
Facility i = 0x9F8B0100A11502013D020100800D43454C4C554C41522043414C4C
0xA11502013D020100800D43454C4C554C41522043414C4C
Invoke Id = 61
Operation = CallingName
Name Presentation Allowed Extended
Name = CELLULAR CALL
Aug 14 18:16:48.422: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8DBB
Aug 14 18:16:48.462: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8DBB
Aug 14 18:16:48.510: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0DBB
Aug 14 13:16:48.514: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 6087707050 N/A
Aug 14 13:16:54.514: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 6087707050 N/A
Aug 14 18:16:57.534: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 6088733379
Aug 14 18:16:57.534: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x2BF0 callID = 0xAB71 switch = primary-ni interface = User
Aug 14 18:16:57.534: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x2BF0
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
Invoke Id = 60
Calling Party Number i = 0x2183, '6088733379'
Called Party Number i = 0xC1, '18887450708'
Aug 14 18:16:57.662: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xABF0
Cause i = 0x809C - Invalid number format (incomplete number)
Aug 14 13:16:57.670: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 68D7E94CC5D811E0941A001D709F07A0, SetupTime 13:16:57.660 CDT Sun Aug 14 2011, PeerAddress 918887450708, PeerSubAddress , DisconnectCause 1C , DisconnectText invalid number (28), ConnectTime 13:16:57.660 CDT Sun Aug 14 2011, DisconnectTime 13:16:57.660 CDT Sun Aug 14 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 14 13:16:57.670: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/14/2011 13:16:57.530,cgn:6088733379,cdn:918887450708,frs:0,fid:422679,fcid:68D7E94CC5D811E0941A001D709F07A0,legID:2F17B,bguid:68D7E94CC5D811E0941A001D709F07A0
Aug 14 18:16:57.678: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 6088733379
Aug 14 18:16:57.678: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x2BF1 callID = 0xAB72 switch = primary-ni interface = User
Aug 14 18:16:57.678: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x2BF1
Standard = CCITT
Invoke Id = 60
Aug 14 18:16:57.762: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xABF1
Aug 14 13:16:57.770: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 68D7E94CC5D811E0941A001D709F07A0, SetupTime 13:16:57.760 CDT Sun Aug 14 2011, PeerAddress 918887450708, PeerSubAddress , DisconnectCause 1C , DisconnectText invalid number (28), ConnectTime 13:16:57.760 CDT Sun Aug 14 2011, DisconnectTime 13:16:57.760 CDT Sun Aug 14 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 14 13:16:57.770: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/14/2011 13:16:57.674,cgn:6088733379,cdn:918887450708,frs:0,fid:422680,fcid:68D7E94CC5D811E0941A001D709F07A0,legID:2F17C,bguid:68D7E94CC5D811E0941A001D709F07A0
Aug 14 13:17:07.782: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 68D7E94CC5D811E0941A001D709F07A0, SetupTime 13:16:57.772 CDT Sun Aug 14 2011, PeerAddress 918887450708, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 13:17:07.772 CDT Sun Aug 14 2011, DisconnectTime 13:17:07.772 CDT Sun Aug 14 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 14 13:17:07.782: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/14/2011 13:16:57.774,cgn:6087707050,cdn:918887450708,frs:0,fid:422681,fcid:68D7E94CC5D811E0941A001D709F07A0,legID:2F17D,bguid:68D7E94CC5D811E0941A001D709F07A0
Aug 14 13:17:17.794: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 68D7E94CC5D811E0941A001D709F07A0, SetupTime 13:17:07.794 CDT Sun Aug 14 2011, PeerAddress 918887450708, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 13:17:17.794 CDT Sun Aug 14 2011, DisconnectTime 13:17:17.794 CDT Sun Aug 14 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Aug 14 13:17:17.794: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/14/2011 13:17:07.786,cgn:6087707050,cdn:918887450708,frs:0,fid:422682,fcid:68D7E94CC5D811E0941A001D709F07A0,legID:2F17E,bguid:68D7E94CC5D811E0941A001D709F07A0
Aug 14 18:17:21.263: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0DBB
Cause i = 0x8090 - Normal call clearing
Aug 14 13:17:21.263: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from 6087707050 , call lasted 32 seconds
Aug 14 18:17:21.263: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8DBB
Aug 14 13:17:21.283: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 68DB92D4C5D811E0915898DAB151FC9B, SetupTime 13:16:48.393 CDT Sun Aug 14 2011, PeerAddress 603, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 13:16:48.453 CDT Sun Aug 14 2011, DisconnectTime 13:17:21.273 CDT Sun Aug 14 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 616, TransmitBytes 98560, ReceivePackets 304, ReceiveBytes 48481
Aug 14 13:17:21.283: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CXFER,ft:08/14/2011 13:16:57.526,frs:0,fid:422675,xconsID:,fcid:68D7E94CC5D811E0941A001D709F07A0,legID:2F179,xrsn:0,xsts:5,Xor:603,Xee:6087707050,Xto:918887450708,bguid:68DB92D4C5D811E0915898DAB151FC9B
Aug 14 13:17:21.283: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CFA,ft:08/14/2011 13:16:48.394,frs:0,fid:422671,fcid:68D7E94CC5D811E0941A001D709F07A0,legID:2F179,frson:1,fdcnt:0,fwder:379,fwdee:6087707050,fwdto:603,frm:379,bguid:68DB92D4C5D811E0915898DAB151FC9B
Aug 14 13:17:21.283: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/14/2011 13:16:48.394,cgn:6087707050,cdn:603,frs:0,fid:422673,fcid:68DB92D4C5D811E0915898DAB151FC9B,legID:2F179,bguid:68DB92D4C5D811E0915898DAB151FC9B
Aug 14 18:17:21.311: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0DBB
08-14-2011 01:19 PM
Hi Brian.
Here is your problem.
You have probably ro check your dest number cause your provider is unrecognizing the destination numebr.
LMK
Carlo
08-15-2011 05:54 AM
That's odd that it would say that. The number is definitely correct, and can successfully be dialed directly. In addition, if accessing the AA through its internal extension, the outbound call connects successfully. It's only when an outside caller accesses the AA that the transfer fails.
Below is the output of a debug isdn q931 when accessing the AA internally. In this case, the call transferred successfully.
Cisco2821#sh log
Syslog logging: enabled (0 messages dropped, 32493 messages rate-limited,
Console logging: level debugging, 592462 messages logged, xml disabled,
filtering disabled
filtering disabled
Buffer logging: level debugging, 34085 messages logged, xml disabled,
filtering disabled
filtering disabled
Aug 15 12:51:46.261: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 6088777412
Aug 15 12:51:46.265: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x2BF3 callID = 0xAB74 switch = primary-ni interface = User
Aug 15 12:51:46.265: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x2BF3
Standard = CCITT
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '6088777412'
Called Party Number i = 0x80, '18887450708'
Plan:Unknown, Type:Unknown
Aug 15 12:51:46.661: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xABF3
Aug 15 12:51:48.313: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callref = 0xABF3
Progress Ind i = 0x8088 - In-band info or appropriate now available
Aug 15 12:51:49.313: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xABF3
Aug 15 07:51:49.313: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 18887450708 N/A
Aug 15 12:51:49.313: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x2BF3
Aug 15 07:51:49.329: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 274933F0C67411E0923398DAB151FC9B, SetupTime 07:51:39.879 CDT Mon Aug 15 2011, PeerAddress 603, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 07:51:39.919 CDT Mon Aug 15 2011, DisconnectTime 07:51:49.329 CDT Mon Aug 15 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 309, TransmitBytes 49440, ReceivePackets 166, ReceiveBytes 26401
Aug 15 07:51:49.329: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CXFER,ft:08/15/2011 07:51:46.253,frs:0,fid:422804,xconsID:,fcid:268E6EBCC67411E0922F98DAB151FC9B,legID:2F1C6,xrsn:0,xsts:5,Xor:603,Xee:112,Xto:918887450708,bguid:274933F0C67411E0923398DAB151FC9B
Aug 15 07:51:51.461: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 268E6EBCC67411E0922F98DAB151FC9B, SetupTime 07:51:38.657 CDT Mon Aug 15 2011, PeerAddress 112, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 07:51:39.937 CDT Mon Aug 15 2011, DisconnectTime 07:51:51.451 CDT Mon Aug 15 2011, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 465, ReceiveBytes 74400
Aug 15 07:51:51.461: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CXFER,ft:08/15/2011 07:51:46.257,frs:0,fid:422807,xconsID:,fcid:268E6EBCC67411E0922F98DAB151FC9B,legID:2F1C5,xrsn:0,xsts:5,Xor:603,Xee:112,Xto:918887450708,bguid:268E6EBCC67411E0922F98DAB151FC9B
Aug 15 07:51:51.461: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:CFA,ft:08/15/2011 07:51:39.873,frs:0,fid:422801,fcid:268E6EBCC67411E0922F98DAB151FC9B,legID:2F1C6,frson:1,fdcnt:1,fwder:379,fwdee:112,fwdto:603,frm:379,bguid:268E6EBCC67411E0922F98DAB151FC9B
Aug 15 07:51:51.461: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/15/2011 07:51:38.648,cgn:112,cdn:,frs:0,fid:422798,fcid:268E6EBCC67411E0922F98DAB151FC9B,legID:2F1C5,bguid:268E6EBCC67411E0922F98DAB151FC9B
Aug 15 07:51:51.477: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 18887450708 N/A
Aug 15 12:51:51.477: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x2BF3
Aug 15 12:51:51.713: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0xABF3
Aug 15 12:51:51.717: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x2BF3
08-16-2011 12:29 AM
Hi Brian.
Try to add the following config to your VG and see if it makes some diferences.
After that, please post me again a debug isdn q931
voice translation-rule 10
rule 1 // // type any unknown plan any unknow
voice translation-profile change_plan
translate called 10
translation-profile outgoing change_plan
Thanks.
Bye
Carlo
08-20-2011 08:49 AM
Hi Brian.
Did you solve your problem?
Please let me know
Carlo
08-22-2011 08:15 AM
Hi Carlo. I wasn't able to try your last suggestion -- I've been out of the office for the past week and will be out again this week as well. While I'm out I did hire a contractor to attempt to resolve the solution. They'll be coming in to take a look this week -- I'll post back here with their solution.
Thanks for all your prior suggestions!
