11-24-2016 01:06 AM - edited 03-17-2019 08:46 AM
Hi !
I need to delete several CSS from cucm 9.1 , but cannot ,, it throws an error as written below.
Even though i followed some post from ucgurella.com and support forum ,,,i could not do so ,, they suggest to go thru CLI ,, but every time i end wtih some errors or the info displayed is not relevant to delete. i could find the dependency of CSS thru gui or CLI .
any body having the correct way to delete
error "The pkid column in the callingsearchspace table in the database is being referenced from another table. Please check the dependency records, remove the reference"
11-24-2016 02:47 AM
Hi Maqsood,
If you have already tried the steps given in the following links and the issue persists then you shoulf engage TAC
https://supportforums.cisco.com/document/119616/unable-delete-couple-calling-search-space-form-cucm-page
http://www.ucguerrilla.com/2013/07/cucm-sql-queries-finding-that-css.html
Manish
11-27-2016 04:09 AM
thank u manish ! appreciate u r response !
11-27-2016 04:11 AM
Below are SQL query to identify the problematic CSS !
run sql select * from callingsearchspace where name ="CSS-internal"
cli result:
pkid name description dialplanwizardgenid clause resettoggle tkreset tkpartitionusage
d1257ca3-e53a-f83b-5e8a-dabf97f2c0df CSS-internal REF NULL DAM_BRN_F2C3_R29:PT-Phones f 2 99
take the PKID from the previous result:
run sql select pkid, dnorpattern from numplan where fkcallingsearchspace_sharedlineappear = "d1257ca3-e53a-f83b-5e8a-dabf97f2c0df"
cli result:
pkid dnorpattern
6d84722f-b7e2-81cc-e76c-24b7f88a2349 3466578
then search for dnorpattern in cucm gui : ex: 3466578 ,, from phone template ... delete the template or change the css to different css...
then delete the problematic css: CSS-internal
i got those query from TAC engineer !
11-24-2016 08:15 AM
Common thing folks miss is an entity being assigned to BAT templates which does not show on the dependency records. Make sure there are no BAT templates referencing this CSS.
