Cannot dial out in Fallback mode
Jason Spring
We are running CUCM and when we lose connection to CUCM, CM fallback is enabled. The rpoblem I am having is that the phones are allowing me to only dial 4 digits. We are using a h.323 gateway and everything works properly when connected to CUCM.
What am I missing? Thanks in advance.
Here is my config:
voice-port 0/0/0
connection plar opx 6533
description Hunt 1 504.368.4395
voice-port 0/0/1
connection plar opx 3653
description Hunt 2 504.365.8228
voice-port 0/0/2
description Hunt 3 504.362.9182
voice-port 0/0/3
connection plar opx 6532
description Sales Manager 504.365.8783
ccm-manager fallback-mgcp
mgcp profile default
sccp local GigabitEthernet0/0.2
sccp ccm 10.136.0.201 identifier 1 version 7.0
sccp ccm 10.122.1.201 identifier 2 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.2
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register Buca-1801_XCODE
dspfarm profile 1 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 7
associate application SCCP
dial-peer voice 1 pots
description Main Inbound Dial Peer
destination-pattern .T
incoming called-number .
direct-inward-dial
dial-peer voice 101 pots
description Outbound 10-Digit Dial Peer
preference 1
destination-pattern 9[2-9]..[2-9]......
progress_ind alert enable 8
port 0/0/3
forward-digits 10
dial-peer voice 102 pots
preference 2
port 0/0/2
forward-digits 10
dial-peer voice 103 pots
preference 3
port 0/0/1
forward-digits 10
dial-peer voice 104 pots
preference 4
port 0/0/0
forward-digits 10
dial-peer voice 111 pots
description Outbound LD Dial Peer
preference 1
destination-pattern 91[2-9]..[2-9]......
port 0/0/3
forward-digits 11
dial-peer voice 112 pots
preference 2
port 0/0/2
forward-digits 11
dial-peer voice 113 pots
preference 3
port 0/0/1
forward-digits 11
dial-peer voice 114 pots
preference 4
port 0/0/0
forward-digits 11
dial-peer voice 9111 pots
description Outbound 911 Dial Peer
preference 1
destination-pattern 9911
port 0/0/3
forward-digits 3
dial-peer voice 9112 pots
preference 2
port 0/0/2
forward-digits 3
dial-peer voice 9113 pots
preference 3
port 0/0/1
forward-digits 3
dial-peer voice 9114 pots
preference 4
dial-peer voice 1000 voip
description Outbound 7-Digit Dial Peer
preference 2
destination-pattern [1-9]...$
progress_ind setup enable 3
no modem passthrough
session target ipv4:10.136.0.201
voice-class codec 1
voice-class h323 2
dtmf-relay h245-alphanumeric
fax rate disable
fax protocol pass-through g711ulaw
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 1001 voip
preference 1
modem passthrough nse codec g711ulaw
session target ipv4:10.122.1.201
voice-class codec 1
voice-class h323 2
fax rate disable
no vad
dial-peer voice 105 pots
preference 1
destination-pattern 9[2-9]......
port 0/0/0
forward-digits 7
dial-peer voice 106 pots
preference 2
port 0/0/1
forward-digits 7
dial-peer voice 107 pots
preference 3
port 0/0/2
forward-digits 7
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.136.53.1 port 2000 strict-match
max-ephones 16
max-dn 8
Harmit Singh
Hi Jason,
Can you capture the following debugs for an outbound call in fallback mode:
debug voip ccapi inout
debug isdn q931
Looks like the gateway is matching the wrong dialpeer i.e. 1000 / 1001 voip dialpeers.  Do you have any reason for configuring destination-pattern as [1-9]...$? In other words, do you have any 9xxx patterns on your CUCM which someone dials from the PSTN world? If not, then I would change the destination pattern to something like [1-8]...$ to avoid the overlapping patterns.
HTH.
Harmit.
Harmit Singh
Hi Jason,
debug isdn q931
HTH.
Harmit.
Thats exactly what it is doing.
Funny thing was that I went to go change the dial peers for 1000 and 1001 to what you suggested and removed the 9, now it works!!!
Hi Jason,
Glad to know that did the trick :-) Please rate if helpful and mark as answered.
Harmit.
