What type of card for a NEC CCIS circuit?
Hello all,
I was wondering if anyone knew what type of card would be required for a Cisco 2921 to emulate a point to point T1 using CCIS coming from the NEC 2000?
Matt
18 Replies 18
paolo bevilacqua
VWIC3-1MFT-T1/E1 and PVDM3 modules.
We have 2921 ISR with a VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 and
32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card.
Do you have any idea what the framing and signaling  and switch type should be?
Default PRI settings should be fine.
http://www.necunifiedsolutions.com/main/Products/ProProduct.asp?solid=11&prodid=70
Thank you for the nice rating and good luck!
Brandon Svec
Level 7
Level 7
CCIS is a proprietary NEC protocol and Cisco cannot operate with it directly.
However- the NEAX2000 with the same T1 card can be configured for regular tie lines or qsig/PRI.
Paolo is correct about the hardware required, but just be clear that you will never get the systems talking if the NEC is configured for CCIS.
You will need to work with an NEC tech to make this work.
-- please remember to rate and mark answered helpful posts --
Hi Brandon,
On the Cisco, there are two techniques to make proprietary protocols to work over VoIP, even before taking the route of Circuit Emulation, that is much more expensive.
First, is tunneling of Q.931 messages in H.323 or SIP. Since the CCIS appears to be based on Q.931, that alone may suffice.
Second, is Transparent CCS. This way, the signalling channel is totally un-interpreted, and anything received is sent the other side. The B channels are transported all the time with 'trunk commands' with the option of VAD and compression, so the bandwidth optimization is still there.
Using one of the two will get any third party system going, hofully they can then migrate the entire system to Cisco at some point.
Thanks. Would you have an example of a config using transparent ccs?
Or a config of
tunneling of Q.931
Hi Mathew,
Here is a config and troubleshooting doc for TCCS:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800a96c1.shtml
HTH.
Harmit.
So for a T1 would it look like this?
ds0-group 0 timeslots 24 type ext-sig
ds0-group 1 timeslots 1 type ext-sig
ds0-group 2 timeslots 2 type ext-sig
ds0-group 3 timeslots 3 type ext-sig
ds0-group 4 timeslots 4 type ext-sig
ds0-group 5 timeslots 5 type ext-sig
ds0-group 6 timeslots 6 type ext-sig
ds0-group 7 timeslots 7 type ext-sig
ds0-group 8 timeslots 8 type ext-sig
ds0-group 9 timeslots 9 type ext-sig
ds0-group 10 timeslots 10 type ext-sig
ds0-group 11 timeslots 11 type ext-sig
ds0-group 12 timeslots 12 type ext-sig
ds0-group 13 timeslots 13 type ext-sig
ds0-group 14 timeslots 14 type ext-sig
ds0-group 15 timeslots 15 type ext-sig
ds0-group 16 timeslots 16 type ext-sig
ds0-group 17 timeslots 17 type ext-sig
ds0-group 18 timeslots 18 type ext-sig
ds0-group 19 timeslots 19 type ext-sig
ds0-group 20 timeslots 20 type ext-sig
ds0-group 21 timeslots 21 type ext-sig
ds0-group 22 timeslots 22 type ext-sig
ds0-group 22 timeslots 23 type ext-sig
Do you know if those connection trunks can use wild cards?
I tried to enter in connection trunk 98.. and it rejected it.
No wild cards in conenctiont runk (it would not make sense).
You can use them in the voip dial-peer.
To begin, just configure as per example.
For some reason we are receiving line code errors when connected to the NEC 2000 into the VWIC3-mft-t1/e1.
Here is the config of the side with the line code errors:
controller T1 0/0/0
framing SF
linecode ami
cablelength long 0db
ds0-group 23 timeslots 23 type ext-sig
voice-port 0/0/0:0
timeouts call-disconnect 3
timeouts wait-release 3
connection trunk 5001 answer-mode
voice-port 0/0/0:1
connection trunk 8001 answer-mode
voice-port 0/0/0:2
connection trunk 8002 answer-mode
voice-port 0/0/0:3
connection trunk 8003 answer-mode
voice-port 0/0/0:4
connection trunk 8004 answer-mode
voice-port 0/0/0:5
connection trunk 8005 answer-mode
voice-port 0/0/0:6
connection trunk 8006 answer-mode
voice-port 0/0/0:7
connection trunk 8007 answer-mode
voice-port 0/0/0:8
connection trunk 8008 answer-mode
voice-port 0/0/0:9
connection trunk 8009 answer-mode
voice-port 0/0/0:10
connection trunk 8010 answer-mode
voice-port 0/0/0:11
connection trunk 8011 answer-mode
voice-port 0/0/0:12
connection trunk 8012 answer-mode
voice-port 0/0/0:13
connection trunk 8013 answer-mode
voice-port 0/0/0:14
connection trunk 8014 answer-mode
voice-port 0/0/0:15
connection trunk 8015 answer-mode
voice-port 0/0/0:16
connection trunk 8016 answer-mode
voice-port 0/0/0:17
connection trunk 8017 answer-mode
voice-port 0/0/0:18
connection trunk 8018 answer-mode
voice-port 0/0/0:19
connection trunk 8019 answer-mode
voice-port 0/0/0:20
connection trunk 8020 answer-mode
voice-port 0/0/0:21
connection trunk 8021 answer-mode
voice-port 0/0/0:22
connection trunk 8022 answer-mode
voice-port 0/0/0:23
connection trunk 8023 answer-mode
dial-peer voice 3001 pots
destination-pattern 3001
port 0/0/0:0
dial-peer voice 6001 pots
destination-pattern 6002
port 0/0/0:1
dial-peer voice 6002 pots
destination-pattern 6003
port 0/0/0:2
dial-peer voice 6003 pots
port 0/0/0:3
dial-peer voice 6004 pots
destination-pattern 6004
port 0/0/0:4
dial-peer voice 6005 pots
destination-pattern 6005
port 0/0/0:5
dial-peer voice 6006 pots
destination-pattern 6006
port 0/0/0:6
dial-peer voice 6007 pots
destination-pattern 6007
port 0/0/0:7
dial-peer voice 6008 pots
destination-pattern 6008
port 0/0/0:8
dial-peer voice 6009 pots
destination-pattern 6009
port 0/0/0:9
dial-peer voice 6010 pots
destination-pattern 6010
port 0/0/0:10
dial-peer voice 6011 pots
destination-pattern 6011
port 0/0/0:11
dial-peer voice 6012 pots
destination-pattern 6012
port 0/0/0:12
dial-peer voice 6013 pots
destination-pattern 6013
port 0/0/0:13
dial-peer voice 6014 pots
destination-pattern 6014
port 0/0/0:14
dial-peer voice 6015 pots
destination-pattern 6015
port 0/0/0:15
dial-peer voice 6016 pots
destination-pattern 6016
port 0/0/0:16
dial-peer voice 6017 pots
destination-pattern 6017
port 0/0/0:17
dial-peer voice 6018 pots
destination-pattern 6018
port 0/0/0:18
dial-peer voice 6019 pots
destination-pattern 6019
port 0/0/0:19
dial-peer voice 6020 pots
destination-pattern 6020
port 0/0/0:20
dial-peer voice 6021 pots
destination-pattern 6021
port 0/0/0:21
dial-peer voice 6022 pots
destination-pattern 6022
port 0/0/0:22
dial-peer voice 6023 pots
destination-pattern 6023
port 0/0/0:23
dial-peer voice 8000 voip
destination-pattern 80..
session target ipv4:10.181.38.151
dial-peer voice 5001 voip
answer-address 3001
destination-pattern 5001
codec clear-channel
Here is the router that comes up clean:
controller T1 0/0
framing sf
linecode ami
voice-port 0/0:3
connection trunk 6003
voice-port 0/0:4
connection trunk 6004
voice-port 0/0:5
connection trunk 6005
voice-port 0/0:6
connection trunk 6006
voice-port 0/0:7
connection trunk 6007
voice-port 0/0:8
connection trunk 6008
voice-port 0/0:9
connection trunk 6009
voice-port 0/0:10
connection trunk 6010
voice-port 0/0:11
connection trunk 6011
voice-port 0/0:12
connection trunk 6012
voice-port 0/0:13
connection trunk 6013
voice-port 0/0:14
connection trunk 6014
voice-port 0/0:15
connection trunk 6015
voice-port 0/0:16
connection trunk 6016
voice-port 0/0:17
connection trunk 6017
voice-port 0/0:18
connection trunk 6018
voice-port 0/0:19
connection trunk 6019
voice-port 0/0:20
connection trunk 6020
voice-port 0/0:21
connection trunk 6021
voice-port 0/0:22
connection trunk 6022
voice-port 0/0:23
connection trunk 6023
voice-port 0/0:0
connection trunk 3001
voice-port 0/0:1
connection trunk 6001
voice-port 0/0:2
connection trunk 6002
dial-peer voice 5001 pots
port 0/0:0
dial-peer voice 8001 pots
destination-pattern 8001
port 0/0:1
dial-peer voice 8002 pots
destination-pattern 8002
port 0/0:2
dial-peer voice 8003 pots
destination-pattern 8003
port 0/0:3
dial-peer voice 8004 pots
destination-pattern 8004
port 0/0:4
dial-peer voice 8005 pots
destination-pattern 8005
port 0/0:5
dial-peer voice 8006 pots
destination-pattern 8006
port 0/0:6
dial-peer voice 8007 pots
destination-pattern 8007
port 0/0:7
dial-peer voice 8008 pots
destination-pattern 8008
port 0/0:8
dial-peer voice 8009 pots
destination-pattern 8009
port 0/0:9
dial-peer voice 8010 pots
destination-pattern 8010
port 0/0:10
dial-peer voice 8011 pots
destination-pattern 8011
port 0/0:11
dial-peer voice 8012 pots
destination-pattern 8012
port 0/0:12
dial-peer voice 8013 pots
destination-pattern 8013
port 0/0:13
dial-peer voice 8014 pots
destination-pattern 8014
port 0/0:14
dial-peer voice 8015 pots
destination-pattern 8015
port 0/0:15
dial-peer voice 8016 pots
destination-pattern 8016
port 0/0:16
dial-peer voice 8017 pots
destination-pattern 8017
port 0/0:17
dial-peer voice 8018 pots
destination-pattern 8018
port 0/0:18
dial-peer voice 8019 pots
destination-pattern 8019
port 0/0:19
dial-peer voice 8020 pots
destination-pattern 8020
port 0/0:20
dial-peer voice 8021 pots
destination-pattern 8021
port 0/0:21
dial-peer voice 8022 pots
destination-pattern 8022
port 0/0:22
dial-peer voice 8023 pots
destination-pattern 8023
port 0/0:23
dial-peer voice 3001 voip
answer-address 5001
session target ipv4:10.1.106.1
codec clear-channel
dial-peer voice 6000 voip
destination-pattern 60..
