Cannot disable call forward on Cisco IP 7960
Ada2
Call forwarding was enabled on Cisco IP phone 7960, and cannot disable the function.  Have pressed softkey numerous times, waited for double-beep, but call forwarding remains enabled.  Please help
Jaime Valencia
Try to disable it from CUCM or CME, if you're an end user, you should be reaching out to your IT department for this.
java
if this helps, please rate
