Outbound call connects after 15 sec delay - E1 R2 Signaling
GM2020
Hi Guys,
Need a help to figure out what is causing the call connect delay..
It is taking 15 sec delay from the time it matched the outbound dial-peer
Call placed @ 19:09:06
Could see logs hitting VG at the same time - 19:09:06
But if you notice the logs the gaps is between 19:09:06 - 19:09:22.265
This is controller config :
controller E1 0/1/0
clock source line primary
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country telmex
category 2
answer-signal group-b 1
ani-digits min 0 max 10
ani-timeout 1
groupa-callerid-end
Outbound Dial-peer matched :
dial-peer voice 10004 pots
description H323-SRST POTS dial-peer
translation-profile outgoing OUTPSTN
preference 1
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
port 0/1/0:0
043503: Oct 19 19:09:06.142 UTC: //-1/80EA8F432A00/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=123456
----- ccCallInfo IE subfields -----
cisco-ani=123456
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=9018000XXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
043504: Oct 19 19:09:06.142 UTC: //-1/80EA8F432A00/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F04B1749300, Call Info(
Calling Number=123456,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=9018000XXXXXX(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=3230, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=269
043505: Oct 19 19:09:06.142 UTC: //-1/80EA8F432A00/CCAPI/ccCheckClipClir:
In: Calling Number=123456(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
043506: Oct 19 19:09:06.142 UTC: //-1/80EA8F432A00/CCAPI/ccCheckClipClir:
Out: Calling Number=123456(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
043507: Oct 19 19:09:06.142 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043508: Oct 19 19:09:06.142 UTC: :cc_get_feature_vsa malloc success
043509: Oct 19 19:09:06.142 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043510: Oct 19 19:09:06.142 UTC: cc_get_feature_vsa count is 1
043511: Oct 19 19:09:06.142 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043512: Oct 19 19:09:06.142 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:139658156120396,feature_id:269
043513: Oct 19 19:09:06.142 UTC: //269/80EA8F432A00/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=123456(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=9018000XXXXXX(TON=Unknown, NPI=Unknown))
043514: Oct 19 19:09:06.143 UTC: //269/80EA8F432A00/CCAPI/cc_process_call_setup_ind:
Event=0x7F04B2CB32A8
043515: Oct 19 19:09:06.143 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 9018000XXXXXX
043516: Oct 19 19:09:06.143 UTC: //269/80EA8F432A00/CCAPI/ccCallSetContext:
Context=0x7F04BB66ECB0
043517: Oct 19 19:09:06.143 UTC: //269/80EA8F432A00/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 269 with tag 3230 to app "_ManagedAppProcess_Default"
043518: Oct 19 19:09:06.143 UTC: //269/80EA8F432A00/CCAPI/ccCallProceeding:
043519: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=10004, Params=0x7F04BB678BC8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
043520: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/ccCheckClipClir:
In: Calling Number=5583110315(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
043521: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/ccCheckClipClir:
Out: Calling Number=5583110315(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
043522: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/ccCallSetupRequest:
Destination Pattern=9T, Called Number=9018000XXXXXX, Digit Strip=TRUE
043523: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/ccCallSetupRequest:
Calling Number=5583110315(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Redirect Number=, Display Info=
Account Number=123456, Final Destination Flag=TRUE,
Guid=80EA8F43-B24C-919E-2A00-35030A09AA43, Outgoing Dial-peer=10004
043524: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=5583110315
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=9018000XXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
043525: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F04C4C3B210, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=5583110315,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=9018000XXXXXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10004, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
043526: Oct 19 19:09:06.144 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043527: Oct 19 19:09:06.144 UTC: :cc_get_feature_vsa malloc success
043528: Oct 19 19:09:06.144 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043529: Oct 19 19:09:06.144 UTC: cc_get_feature_vsa count is 2
043530: Oct 19 19:09:06.144 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043531: Oct 19 19:09:06.144 UTC: :FEATURE_VSA attributes are: feature_name:0,feature_time:139658156120172,feature_id:270
043532: Oct 19 19:09:06.144 UTC: //270/80EA8F432A00/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
043533: Oct 19 19:09:06.144 UTC: //270/80EA8F432A00/CCAPI/ccCallSetContext:
Context=0x7F04BB678B48
043534: Oct 19 19:09:06.144 UTC: //269/80EA8F432A00/CCAPI/ccSaveDialpeerTag:
043535: Oct 19 19:09:06.509 UTC: //270/80EA8F432A00/CCAPI/cc_api_call_proceeding:
Interface=0x7F04C4C3B210, Progress Indication=NULL(0)
043536: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_call_alert:
Interface=0x7F04C4C3B210, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
043537: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
043538: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccCallAlert:
043539: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
043540: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
043541: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID1=0x10D, gcid=0-0-0-0, tag=0x0)
043542: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID2=0x10E, gcid=0-0-0-0, tag=0x0)
043543: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=269, Call Id2=270, Tag=0x0
043544: Oct 19 19:09:22.265 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043545: Oct 19 19:09:22.265 UTC: cc_api_get_xcode_stream : 4983
043546: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/cc_api_bridge_done:
Conference Id=0x6B, Source Interface=0x7F04B1749300, Source Call Id=269,
Destination Call Id=270, Disposition=0x0, Tag=0x0
043547: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_bridge_done:
Conference Id=0x6B, Source Interface=0x7F04C4C3B210, Source Call Id=270,
Destination Call Id=269, Disposition=0x0, Tag=0xFFFFFFFFFFFFFFFF
043548: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/cc_generic_bridge_done:
043549: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x6B, Destination Call Id=270)
043550: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x6B, Destination Call Id=269)
043551: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccConferenceCreate:
043552: Oct 19 19:09:22.265 UTC: confID:0x6B; callEntry1 callID1:0x10D, type:1; callEntry2 callID2:0x10E, type:6
043553: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_caps_ind:
Destination Interface=0x7F04B1749300, Destination Call Id=269, Source Call Id=270,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
043554: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
043555: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=269
043556: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_get_called_ccm_detected:
043557: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/ccCallNotify:
043558: Oct 19 19:09:22.265 UTC: //270/80EA8F432A00/CCAPI/cc_api_get_called_ccm_detected:
043559: Oct 19 19:09:22.265 UTC: //269/80EA8F432A00/CCAPI/cc_api_get_delay_xport:
CallInfo(delay xport=FALSE)
043560: Oct 19 19:09:22.266 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043561: Oct 19 19:09:22.266 UTC: cc_api_get_xcode_stream : 4983
043562: Oct 19 19:09:22.266 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043563: Oct 19 19:09:22.266 UTC: cc_api_get_xcode_stream : 4983
043564: Oct 19 19:09:22.266 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043565: Oct 19 19:09:22.266 UTC: cc_api_get_xcode_stream : 4983
043566: Oct 19 19:09:22.266 UTC: //269/80EA8F432A00/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x6B, Call Id1=269, Call Id2=270
043567: Oct 19 19:09:22.503 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043568: Oct 19 19:09:22.503 UTC: cc_api_get_xcode_stream : 4983
043569: Oct 19 19:09:22.503 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043570: Oct 19 19:09:22.503 UTC: cc_api_get_xcode_stream : 4983
043571: Oct 19 19:09:22.559 UTC: //269/80EA8F432A00/CCAPI/cc_api_caps_ind:
Destination Interface=0x7F04C4C3B210, Destination Call Id=270, Source Call Id=269,
Caps(Codec=0x800, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=2)
043572: Oct 19 19:09:22.559 UTC: //269/80EA8F432A00/CCAPI/cc_api_caps_ind:
043573: Oct 19 19:09:22.559 UTC: //269/80EA8F432A00/CCAPI/cc_api_caps_ack:
Caps(Codec=g729br8(0x800), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=6463)
043574: Oct 19 19:09:22.559 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043575: Oct 19 19:09:22.559 UTC: cc_api_get_xcode_stream : 4983
043576: Oct 19 19:09:22.560 UTC: //270/80EA8F432A00/CCAPI/cc_api_caps_ack:
043577: Oct 19 19:09:22.560 UTC: //270/80EA8F432A00/CCAPI/cc_api_voice_mode_event:
Call Id=270
043578: Oct 19 19:09:22.560 UTC: //270/80EA8F432A00/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x7F04BB678B48)
043579: Oct 19 19:09:22.843 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043580: Oct 19 19:09:22.843 UTC: cc_api_get_xcode_stream : 4983
043581: Oct 19 19:09:22.843 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043582: Oct 19 19:09:22.843 UTC: cc_api_get_xcode_stream : 4983
043583: Oct 19 19:09:22.844 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043584: Oct 19 19:09:22.844 UTC: cc_api_get_xcode_stream : 4983
043585: Oct 19 19:09:22.844 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043586: Oct 19 19:09:22.844 UTC: cc_api_get_xcode_stream : 4983
043587: Oct 19 19:09:22.844 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043588: Oct 19 19:09:22.844 UTC: cc_api_get_xcode_stream : 4983
043589: Oct 19 19:09:22.844 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043590: Oct 19 19:09:22.844 UTC: cc_api_get_xcode_stream : 4983
043591: Oct 19 19:09:22.940 UTC: //270/80EA8F432A00/CCAPI/cc_api_call_connected:
Interface=0x7F04C4C3B210, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
043592: Oct 19 19:09:22.941 UTC: //270/80EA8F432A00/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
043593: Oct 19 19:09:22.941 UTC: //269/80EA8F432A00/CCAPI/ccCallConnect:
Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
043594: Oct 19 19:09:22.941 UTC: //270/80EA8F432A00/CCAPI/cc_api_get_called_ccm_detected:
043595: Oct 19 19:09:22.941 UTC: //269/80EA8F432A00/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
043596: Oct 19 19:09:22.941 UTC: //269/80EA8F432A00/CCAPI/ccCallNotify:
043597: Oct 19 19:09:22.941 UTC: //270/80EA8F432A00/CCAPI/cc_api_get_called_ccm_detected:
043598: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043599: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043600: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043601: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043602: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043603: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043604: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043605: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043606: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043607: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043608: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043609: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043610: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043611: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043612: Oct 19 19:09:22.941 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043613: Oct 19 19:09:22.941 UTC: cc_api_get_xcode_stream : 4983
043614: Oct 19 19:09:27.481 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043615: Oct 19 19:09:27.481 UTC: cc_api_get_xcode_stream : 4983
043616: Oct 19 19:09:27.481 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043617: Oct 19 19:09:27.481 UTC: cc_api_get_xcode_stream : 4983
043618: Oct 19 19:09:27.593 UTC: //269/80EA8F432A00/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x7F04B1749300, Call Id=269
043619: Oct 19 19:09:27.593 UTC: //269/80EA8F432A00/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
043620: Oct 19 19:09:27.593 UTC: //269/80EA8F432A00/CCAPI/ccConferenceDestroy:
Conference Id=0x6B, Tag=0x0
043621: Oct 19 19:09:27.593 UTC: //269/80EA8F432A00/CCAPI/ccConferenceDestroy:
043622: Oct 19 19:09:27.593 UTC: confID:0x6B; callEntry1 callID1:0x10D, type:1; callEntry2 callID2:0x10E, type:6
043623: Oct 19 19:09:27.593 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043624: Oct 19 19:09:27.593 UTC: cc_api_get_xcode_stream : 4983
043625: Oct 19 19:09:27.593 UTC: //269/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
043626: Oct 19 19:09:27.593 UTC: cc_api_get_xcode_stream : 4983
043627: Oct 19 19:09:27.593 UTC: //269/80EA8F432A00/CCAPI/cc_api_bridge_drop_done:
043628: Oct 19 19:09:27.593 UTC: //270/80EA8F432A00/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=269, Disposition=0x0, Tag=0x0
043629: Oct 19 19:09:27.593 UTC: //269/80EA8F432A00/CCAPI/cc_generic_bridge_done:
043630: Oct 19 19:09:27.594 UTC: //269/80EA8F432A00/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
043631: Oct 19 19:09:27.594 UTC: //269/80EA8F432A00/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
043632: Oct 19 19:09:27.594 UTC: //269/80EA8F432A00/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
043633: Oct 19 19:09:27.594 UTC: //270/80EA8F432A00/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
043634: Oct 19 19:09:27.594 UTC: //270/80EA8F432A00/CCAPI/ccCallDisconnect:
043635: Oct 19 19:09:27.594 UTC: //270/80EA8F432A00/CCAPI/cc_api_get_transfer_info:
043636: Oct 19 19:09:27.630 UTC: //269/80EA8F432A00/CCAPI/cc_api_get_transfer_info:
043637: Oct 19 19:09:27.630 UTC: //269/80EA8F432A00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F04B1749300, Tag=0x0, Call Id=269,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
043638: Oct 19 19:09:27.631 UTC: //269/80EA8F432A00/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
043639: Oct 19 19:09:27.631 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
043640: Oct 19 19:09:27.631 UTC: :cc_free_feature_vsa freeing 7F04B2C91940
043641: Oct 19 19:09:27.631 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
043642: Oct 19 19:09:27.631 UTC: vsacount in free is 1
043643: Oct 19 19:09:27.851 UTC: //270/80EA8F432A00/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F04C4C3B210, Tag=0x0, Call Id=270,
043644: Oct 19 19:09:27.851 UTC: //270/80EA8F432A00/CCAPI/cc_api_call_disconnect_done:
043645: Oct 19 19:09:27.851 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
043646: Oct 19 19:09:27.851 UTC: :cc_free_feature_vsa freeing 7F04B2C91860
043647: Oct 19 19:09:27.851 UTC: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
043648: Oct 19 19:09:27.851 UTC: vsacount in free is 0
iptuser55
Level 6
Level 6
Have you check the t302 timer in CUCM Service Params normally the default is 15000 or 15 sec
Hi iptuser55,
The delay is there even after entering the # after the digits. We have many locations so the CUCM global parameter is not changed
Could you resolve the issue? we are having same problems with a customer R2D E1
The 15-second delay here is not caused by CUCM, but rather by the router. If it were caused by CUCM, he would be experiencing a 15-second delay after dialing before anything was seen in the router. The fact that the router receives the inbound signaling and it waits 15 seconds before proceeding means that the router is the one that is waiting. We would need to see more of his configuration to determine the cause.
Gustavo - May I suggest that you start a new discussion/thread so that your question is fresh in the queue here in the support forums. You can add a link to this conversation in your post if you think it would help us understand your situation.
Maren
