11-28-2012 03:04 PM - edited 03-16-2019 02:26 PM
Hi everybody,
There's a customer that has a cisco 2921 router (Version 15.2(2)T //// "flash:c2900-universalk9-mz.SPA.152-2.T.bin").
It has two FXO ports with phone lines: 1348 and 1074.
The issue is that when they make an outbound call with one line, you can't make at the same time another call with the other line.
Could anybody help me with this? What's wrong? What should be changed on the configuration if it's needed?
Regards.
Patricio
11-28-2012 03:10 PM
It's possible your outbound dial peer(s) are pointing to only one outbound voice port instead of a trunk group. Can you post a show run. Are they using CME or call manager?
11-28-2012 04:15 PM
I believe they use Call Manager.
Here's part of the show run:
voice-port 1/0/0
cptone AR
timeouts interdigit 2
connection plar 2355
station-id name Pater_PHONE
caller-id enable
voice-port 1/0/1
cptone AR
timeouts interdigit 4
timeouts ringing infinity
timing hookflash-in 900 400
station-id name Suc_8_Fax
caller-id enable
voice-port 1/0/2
cptone AR
station-id name Suc_8_Cast
caller-id enable
voice-port 1/0/3
cptone AR
station-id name Suc_8_ATM
caller-id enable
voice-port 1/0/4
cptone AR
station-id name Suc_8_Denver
caller-id enable
voice-port 1/0/5
cptone AR
caller-id enable
voice-port 1/0/6
cptone AR
caller-id enable
voice-port 1/0/7
cptone AR
caller-id enable
voice-port 1/0/8
trunk-group PSTN
supervisory disconnect dualtone mid-call
supervisory custom-cptone country-ar
cptone AR
timeouts call-disconnect 2
shutdown
impedance complex2
description ## LIBRE ##
voice-port 1/0/9
trunk-group PSTN
cptone AR
shutdown
impedance complex2
voice-port 1/0/10
trunk-group PSTN
cptone AR
shutdown
impedance complex2
voice-port 1/0/11
trunk-group PSTN
cptone AR
shutdown
impedance complex2
description ## LINEA3 ##
voice-port 1/0/12
trunk-group PSTN
cptone AR
impedance complex2
description ## 1348 ##
voice-port 1/0/13
trunk-group PSTN
cptone AR
impedance complex2
description ## 1074 ##
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager sccp local Loopback2
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp profile default
sccp ccm 172.25.29.179 identifier 2 version 7.0
sccp ccm 172.31.26.37 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register XCODE_Suc8
associate profile 3 register MTP_Suc8
associate profile 2 register CFB_Suc8
switchback method graceful
dspfarm profile 1 transcode
codec pass-through
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 5
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
dspfarm profile 3 mtp
codec pass-through
codec g711ulaw
maximum sessions software 100
dial-peer cor custom
name PT_Emergencia
name PT_Servicios
name PT_0800
name PT_Locales
name PT_Celulares
name PT_DDN
name PT_DDI
dial-peer cor list dial-peer
dial-peer cor list CSS-Emergencias
member PT_Emergencia
member PT_Servicios
member PT_0800
dial-peer cor list CSS-Locales
member PT_Servicios
member PT_0800
member PT_Locales
dial-peer cor list CSS-Celulares
member PT_Servicios
member PT_0800
member PT_Locales
member PT_Celulares
dial-peer cor list CSS-DDN
member PT_Servicios
member PT_0800
member PT_Locales
member PT_Celulares
member PT_DDN
dial-peer cor list CSS-Loc-DDN
member PT_Servicios
member PT_0800
member PT_Locales
member PT_DDN
dial-peer cor list CSS-DDI
member PT_Servicios
member PT_0800
member PT_Locales
member PT_Celulares
member PT_DDN
member PT_DDI
dial-peer voice 1 voip
description ## Ruta internos 4 digitos - CUCM Activo ##
preference 1
destination-pattern [*1-9]...
session target ipv4:172.31.26.37
voice-class codec 1
voice-class h323 1
dtmf-relay h245-signal h245-alphanumeric
fax-relay ecm disable
fax rate 7200
no vad
dial-peer voice 2 voip
description ## Ruta internos 4 digitos - CUCM Backup ##
preference 2
shutdown
session target ipv4:172.31.86.14
voice-class codec 1
voice-class h323 1
fax rate 7200
no vad
dial-peer voice 100 voip
description ## Ruta Preatendedor WAN ##
service macro
incoming called-number *100
codec g711ulaw
dial-peer voice 101 pots
trunkgroup PSTN
corlist outgoing CSS-Locales
description Locales
destination-pattern 0[3-7].....
dial-peer voice 102 pots
trunkgroup PSTN
corlist outgoing CSS-Celulares
description Celulares 8 Digitos
destination-pattern 015......
prefix 15
dial-peer voice 103 pots
trunkgroup PSTN
corlist outgoing CSS-DDN
description Larga Distancia Nacional
destination-pattern 00[1-3].........
forward-digits 11
dial-peer voice 104 pots
trunkgroup PSTN
corlist outgoing CSS-DDI
description DDI
destination-pattern 00T
prefix 00
dial-peer voice 105 pots
trunkgroup PSTN
description 0800
destination-pattern 008T
prefix 08
dial-peer voice 106 pots
trunkgroup PSTN
corlist outgoing CSS-Emergencias
description Servicios
destination-pattern 01[^5].
forward-digits 3
dial-peer voice 107 pots
trunkgroup PSTN
destination-pattern 1[^5].
forward-digits 3
dial-peer voice 108 pots
trunkgroup PSTN
description 911
destination-pattern 0911
forward-digits 3
dial-peer voice 109 pots
trunkgroup PSTN
description 911
destination-pattern 911
forward-digits 3
dial-peer voice 110 pots
trunkgroup PSTN
description Larga Distancia Nacional Celulares
destination-pattern 00[1-3].15........
forward-digits 13
dial-peer voice 111 pots
trunkgroup PSTN
description Celulares 6 digitos
destination-pattern 00[1-3]...15......
forward-digits 13
dial-peer voice 112 pots
trunkgroup PSTN
description Celulares 7 digitos
destination-pattern 00[1-3]..15.......
forward-digits 13
dial-peer voice 200 pots
destination-pattern 18799999
port 1/0/0
dial-peer voice 201 pots
service stcapp
port 1/0/1
dial-peer voice 202 pots
service stcapp
port 1/0/2
dial-peer voice 203 pots
service stcapp
port 1/0/3
dial-peer voice 204 pots
service stcapp
port 1/0/4
dial-peer voice 205 pots
service stcapp
port 1/0/5
dial-peer voice 206 pots
service stcapp
port 1/0/6
dial-peer voice 207 pots
service stcapp
port 1/0/7
dial-peer voice 208 pots
service macro
shutdown
incoming called-number .
port 1/0/8
dial-peer voice 209 pots
service macro
shutdown
port 1/0/9
dial-peer voice 210 pots
service macro
shutdown
port 1/0/10
dial-peer voice 211 pots
service macro
port 1/0/11
dial-peer voice 212 pots
service macro
port 1/0/12
dial-peer voice 213 pots
service macro
port 1/0/13
dial-peer voice 23551 voip
description ## Ruta HotLine - CUCM Activo ##
preference 1
destination-pattern 2355
voice-class codec 1
voice-class h323 1
fax rate 7200
no vad
dial-peer voice 23552 pots
trunkgroup PSTN
description ## Pater Phone en modo SRST ##
translation-profile outgoing HOTLINE
preference 5
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 0
max-conferences 3 gain -6
transfer-system full-consult
ip source-address 172.25.29.179 port 2000
max-ephones 100
max-dn 96 dual-line
11-28-2012 04:23 PM
Only 2 of your POTS lines are not in shutdown mode, can you test them individually to see if they both work?
You can build a more explicit dial-peer pointing to each voice-port individually rather than the trunkgroup and see if call goes out both times.
HTH,
Chris
11-28-2012 04:27 PM
I'd try removing the trunk group PSTN from the shutdown interfaces. I've run into issues with a trunk group applied to FXO interfaces that are shutdown in certain IOS trains.
Its also possible there is a physical issue with one of the pots lines. You can try pointing one of the PSTN dial peers to each FXO port and testing them seperately to make sure they are both operational.
port 1/0/12
forward-digits 13
make a test long distance call
then change the dial peer to
port 1/0/13
forward-digits 13
and make a test LD call
11-28-2012 04:57 PM
Thanks Chris and Eric for your help!
I'm seeing the customer tomorrow. I'll try with the information that you have given me. I'll tell you how it went.
Thanks again!
Patricio
