Cannot receive incoming fax
fajarwidiastomo
Hello guys,
I have machine fax which cannot receive incoming fax but can send outgoing fax
The PSTN line is using PRI and we connect fax to analog using FXS
-----PRI Line ( ISDN) ---| Voice Gateway |-------FXS-------FAX Machine
im using CUCM ver 8.6 and MGCP protocol with 2981 GW
below is the configuration
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server xxxxxx
ccm-manager config
mgcp
mgcp call-agent xxxx service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability srtp-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
Any help would be appreciated
Thank you
Manish Gogna
Can you share the output of "debug mgcp packets" and "debug voip vtsp all" for an incoming fax failure.
The signaling can be verified as explained in the following link
http://www.cisco.com/c/en/us/support/docs/voice/media-gateway-control-protocol-mgcp/118725-technote-mgcp-00.html
Manish
- Do rate helpful posts -
