Cannot Transfer call to External number CME 7.0
asharsidd
Can someone please help me in resolving this issue for a customer using CME 7.0. They can transfer calls to internal number fine but when they try to transfer an external call to an external number the call just dropes as soon as they hit transfer key. They can make that external call to have consultive transfer while the original call is on hold but then when they try to join these two calls i.e. Original calling party to transferred party - the call just drops. I cannot see any apparent errors on isdn q931. I have attached CCAPI for analysis.
The codecs are fine, I have included supplementary-service command as well under voice service voip but no joy. I have also added dsp services dspfarm and local-bypass command for hairpinning but that didn't help. Customer is saying it use to work before - but it's been 3 months it didn't work and they did not make any chaanges. The router, however, reloaded itself some 3 months before due to a power cut. I am not sure if some config has gone missing since then or some internal fault has developed. Please let me know if there is anything configuration wise needed to make it work. I am adding some running config for your reference.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(20)T1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 24-Sep-08 14:37 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
KeyoCMErouter uptime is 12 weeks, 1 day, 1 hour, 38 minutes
System restarted at 12:44:04 BST Thu Jun 2 2011
System image file is "flash:c2800nm-advipservicesk9-mz.124-20.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.50) with 247808K/14336K bytes of memory.
Processor board ID FCZ11107207
2 FastEthernet interfaces
9 Serial interfaces
1 terminal line
1 Channelized/Clear E1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
logging message-counter syslog
logging buffered 51200 informational
enable secret 5 $1$hTgr$AmCtlTIagoygB.4oppgM90
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
clock timezone GMT 0
clock summer-time BST recurring 4 Sun Mar 1:00 4 Sun Oct 1:00
network-clock-participate wic 2
dot11 syslog
ip source-route
voice-card 0
local-bypass
isdn switch-type primary-net5
voice service pots
supported-language EN
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
redirect ip2ip
fax protocol pass-through g711ulaw
h323
  session transport udp
sip
  header-passing
  registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw bytes 160
codec preference 2 g711alaw bytes 160
codec preference 3 g729r8 bytes 2
dial-peer cor custom
name external
name internal
name banned
dial-peer cor list css-external
member external
member internal
dial-peer cor list css-internal
member internal
dial-peer cor list css-none
member banned
dial-peer voice 10 pots
corlist incoming css-internal
description POTS Default Inbound
incoming called-number .T
direct-inward-dial
dial-peer voice 11 voip
corlist incoming css-none
description VOIP Default Inbound
voice-class codec 1
no vad
dial-peer voice 12 pots
corlist outgoing css-external
description POTS Default Outbound
destination-pattern .T
port 0/2/0:15
telephony-service
load 7914 S00105000300
load 7902 CP7902080001SCCP051117A
load 7905 CP7905080001SCCP051117A
load 7910 P00405000700
load 7912 CP7912080001SCCP051117A
load 7920 cmterm_7920.4.0-02-00
load 7935 P00503010100
load 7936 cmterm_7936.3-3-5-0
load 7960-7940 P00308000500
load 7961 term61.default
load 7970 term70.default
load 7971 term71.default
load ata ATA030100SCCP040211A
max-ephones 42
max-dn 144
ip source-address 172.16.10.1 port 2000
max-redirect 20
caller-id block code *916
calling-number initiator
service phone videoCapability 1
timeouts interdigit 5
timeouts busy 5
timeouts ringing 30
url directories http://172.31.100.1/phone/directory.php
url services http://172.31.100.1/phone/directory.php
url authentication http://172.31.100.1/phone/auth.php
cnf-file location flash:
cnf-file perphone
time-zone 21
date-format dd-mm-yy
voicemail 700
max-conferences 16 gain -6
call-forward pattern .T
web admin system name admin secret 5 $1$g9YV$WM7ahVLpHAEtkEQbyWAjn/
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
night-service code *76
night-service day Sun 00:00 23:59
night-service day Mon 17:30 09:00
night-service day Tue 17:30 09:00
night-service day Wed 17:30 09:00
night-service day Thu 17:30 09:00
night-service day Fri 17:30 09:00
night-service day Sat 00:00 23:59
create cnf-files version-stamp 7960 Jan 08 2009 16:58:24
(This is the ephone/ephone-dn where the call is coming - it has overlay setup for extension '291')
ephone-dn  1  dual-line
no call-waiting beep
number 700
pickup-group 0
label Reception
name Reception
corlist incoming css-external
corlist outgoing css-internal
huntstop channel
no huntstop
hold-alert 30 originator
Omitted
ephone-dn  30  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
call-forward night-service 290
call-forward noan 290 timeout 15
huntstop channel
no huntstop
ephone-dn  31  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
preference 1
huntstop channel
no huntstop
ephone-dn  32  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
preference 2
huntstop channel
no huntstop
ephone-dn  33  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
preference 3
huntstop channel
no huntstop
ephone-dn  34  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
preference 4
huntstop channel
no huntstop
ephone-dn  35  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
preference 5
huntstop channel
no huntstop
ephone-dn  36  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
preference 6
huntstop channel
no huntstop
ephone-dn  37  dual-line
number 291
pickup-group 0
label Main Line
name Main Number
preference 7
huntstop channel
no huntstop
ephone-dn  100
number 801...
mwi on
ephone  1
device-security-mode none
mac-address 001A.6DDE.XXXX
username "reception" password password
type 7960 addon 1 7914
button  1o1,20,21,22,23,24,25,26,27 2o30,37 3o31,36 4o32,35
button  5o33,34
Caller from >> 17XX747XXX Calls their mainline 659005 translated to 291 which is setup as overlay - call is established between ext 291 and
17XX747XXX then Receptionist at ext 291 transfers the caller to an external phone 078XXXXXXXX - She speaks to the person at 078XXXXXXXX that there is a call for him, then hit transfer key so that a call is established between 17XX747XXX  and 078XXXXXXXX but as soon as she hits transfer call drops.
CMErouter#
.Aug 26 13:49:52.045: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98381
        Exclusive, Channel 1
    Progress Ind i = 0x8583 - Origination address is non-ISDN
    Calling Party Number i = 0x2181, '17XX747XXX'
        Plan:ISDN, Type:National
    Called Party Number i = 0x81, '659005'
        Plan:ISDN, Type:Unknown
.Aug 26 13:49:52.049: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0x8001 callID = 0x0F19 switch = primary-net5 interface = User
KeyoCMErouter#
.Aug 26 13:49:52.077: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
.Aug 26 13:49:52.085: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8001
    Progress Ind i = 0x8188 - In-band info or appropriate now available
KeyoCMErouter#
659005 translates to internal number 291:
Call is established with caller 17XX747XXX:
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0x158630   20FA 0x49597274 0/2/0:15.1       0/1:2   291        g711ulaw  10/20020
0x158631   20FA 0x49EBDC98 50/0/30.0               *291        g711ulaw  20020/10
Ext 291 puts Original call on hold and dials a mobile number:
you can see both call legs in show voice call status - the codecs are fine as well.
.Aug 26 13:50:25.745: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0F8B
        Standard = CCITT
    Channel ID i = 0xA98388
        Exclusive, Channel 8
    Progress Ind i = 0x8183 - Origination address is non-ISDN sh voice call st
    Calling Party Number i = 0x0180, '659005'
    Called Party Number i = 0x81, '078XXXXXXXX'
.Aug 26 13:50:25.933: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8F8B
0x158661   33F2 0x49BB7130 50/0/1.0                 78XXXXXXXX g711ulaw  20001/12
0x158662   33F2 0x49597274 0/2/0:15.8       0/1:1  *78XXXXXXXX g711ulaw  12/20001
1 active call found
Please see attched ccapi trace - there are two calls in there, please note when the call is dropped the ccapi says:
   Destination Call Id=1411272, Disposition=0x0, Tag=0x0
.Aug 26 14:36:15.293: //1411272/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2651, Source Interface=0x49597274, Source Call Id=1411272,
   Destination Call Id=1411270, Disposition=0x0, Tag=0x0
.Aug 26 14:36:15.293: //1411270/87E799B5A40A/CCAPI/cc_generic_bridge_done:
.Aug 26 14:36:15.301: //1411270/87E799B5A40A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
.Aug 26 14:36:15.301: //1411270/87E799B5A40A/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
10 Replies 10
asharsidd
Could it be a DSP issue? thoughts..
Asharsidd:
Please check this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a0080816cac.shtml
Also: Could you please include the sh call history voice brief when the transfer fail?
Rad Baver
Thanks Rad. I have gone through that link which says:
"When a call is forwarded, the calling number  remains the same and the Telco does not allow the call to complete  because it expects a different calling number. That is the number from  which the call is redirected. In order to resolve this problem,  configure the translation rule to force ANI for outgoing calls, which  should be the Telco expected value."
Ih this case, all outgoing calls meet a translation rule which changes their ANI to 659005.
voice translation-rule 1
rule 1 /659005/ /291/
voice translation-rule 2
rule 1 /^.*$/ /659005/
voice translation-rule 3
rule 1 /^1/ /01/
rule 2 /^2/ /02/
rule 3 /^3/ /03/
rule 4 /^4/ /04/
rule 5 /^5/ /05/
rule 6 /^6/ /06/
rule 7 /^7/ /07/
rule 8 /^8/ /08/
rule 9 /^9/ /09/
voice translation-profile cid
translate calling 2
voice translation-profile dids
translate calling 3
translate called 1
voice-port 0/2/0:15
translation-profile incoming dids
translation-profile outgoing cid
cptone GB
So I think we are already sending ANI which is what telco is expecting or is it a matter of explicitly applying it under ephone-dn?
Asharsidd:
Is correct: with that config you are already sending ANI. What about
"...Also: Could you please include the sh call history voice brief when the transfer fail?..."
Rad Baver
Hi Rad,
I have collected the traces for you. A call was made from17XX747XXX  to 659005 and then 659005 made an external call to a mobile phone. Call  was established between 659005 and mobile phone while the first call  was on hold. As soon as she hits transfer, the call drops.
.Sep  5 10:06:32.766: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
    Sending Complete
        Standard = CCITT
.Sep   5 10:06:32.766: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0x8001  callID = 0x1099 switch = primary-net5 interface = User
.Sep  5 10:06:32.798: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
.Sep  5 10:06:32.806: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8001
    Progress Ind i = 0x8188 - In-band info or appropriate now available          rerm len 0
.Sep  5 10:06:34.582: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8001
.Sep  5 10:06:34.642: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0001
.Sep  5 10:06:34.646: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 17XX747XXX N/A
% Invalid input detected at '^' marker.
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
.Sep  5 10:06:40.646: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 17XX747XXX N/A
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#trerm len 0           sh deb                term len 0         rerm len 0           sh call hist voice brief
ms. +  + pid:
  dur hh:mm:ss tx:/ rx:/ ()
IP : rtt:
  delay://ms
media inactive detected: media cntrl rcvd: timestamp:
long duration call detected: long duration call duration : timestamp:
  MODEMPASS buf:/ loss /
   last s dur:/s
FR [int dlci cid] vad: dtmf: seq:
  (payload size)
ATM [int vpi/vci cid] vad: dtmf: seq:
  (payload size)
Telephony  (callID) [channel_id]  tx://ms   noise:dBm acom:dBm
  MODEMRELAY  info://  xid:/  total:// disc:
             speeds(bps): local / remote /
Proxy  :
bw: / codec:
  tx:
rx:
Telephony call-legs: 10
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
Total call-legs: 10
29E  : 1573326 -388186892ms.21515 +27600 +30730 pid:20001 Answer 200
dur 00:00:03 tx:0/0 rx:153/24480 10  (normal call clearing (16))
Telephony 50/0/1 (1573326) [50/0/1.0] tx:0/0/0ms g711ulaw noise:0dBm acom:0dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a29E  : 1573327 -388184842ms.21516 +25520 +28860 pid:12  Originate 07773460559
dur 00:00:03 tx:153/25704 rx:156/24960 10  (normal call clearing (16))
Telephony 0/2/0:15 (1573327) [0/2/0.8] tx:3140/3140/0ms g711ulaw noise:-72dBm acom:18dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2B4  : 1573362 -388141892ms.21517 +14780 +148130 pid:20004  Answer 203
dur 00:02:13 tx:0/0 rx:6896/1103360 10  (normal call clearing (16))
Telephony 50/0/4 (1573362) [50/0/4.0] tx:133960/133960/0ms g711ulaw noise:0dBm acom:0dBm
  long duration call detected:n long dur callduration :n/a  timestamp:n/a2B4  : 1573363 -388132622ms.21518 +5500 +139050 pid:12  Originate 01724788325
dur 00:02:13 tx:6896/1158528 rx:6901/1104160 10  (normal call clearing (16))
Telephony 0/2/0:15 (1573363) [0/2/0.8] tx:138050/138050/0ms g711ulaw noise:-55dBm acom:45dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2CA  : 1573398 -387963412ms.21519 +10570 +34220 pid:20001  Answer 200
dur 00:00:23 tx:0/0 rx:1179/188640 10  (normal call clearing (16))
Telephony 50/0/1 (1573398) [50/0/1.0] tx:19040/19040/0ms g711ulaw noise:0dBm acom:0dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2CA  : 1573399 -387961152ms.21520 +8290 +32160 pid:12  Originate 07792346480
dur 00:00:23 tx:1179/198072 rx:1182/189120 10  (normal call clearing (16))
Telephony 0/2/0:15 (1573399) [0/2/0.8] tx:23660/23660/0ms g711ulaw noise:-66dBm acom:51dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2CF  : 1573400 -387918612ms.21521 +2880 +5380 pid:20001  Answer 200
dur 00:00:02 tx:0/0 rx:120/19200 10  (normal call clearing (16))
Telephony 50/0/1 (1573400) [50/0/1.0] tx:0/0/0ms g711ulaw noise:0dBm acom:0dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2CF  : 1573401 -387916342ms.21522 +590 +3850 pid:12  Originate 07912064025
dur 00:00:03 tx:120/20160 rx:123/19680 10  (normal call clearing (16))
Telephony 0/2/0:15 (1573401) [0/2/0.8] tx:2490/2490/0ms g711ulaw noise:-72dBm acom:56dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2279 : 1573403 -387915952ms.21523 +3310 +119570 pid:20020  Originate 291
dur 00:01:56 tx:0/0 rx:5800/928000 10  (normal call clearing (16))
Telephony 50/0/30 (1573403) [50/0/30.0] tx:114640/114640/0ms g711ulaw noise:0dBm acom:0dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2279 : 1573402 -387915982ms.21524 +3490 +119630 pid:10  Answer 017XX747XXX
dur 00:01:56 tx:5800/974400 rx:5803/928480 10  (normal call clearing (16))
Telephony 0/2/0:15 (1573402) [0/2/0.1] tx:116100/116100/0ms g711ulaw noise:-64dBm acom:45dBm
KeyoCMErouter#
.Sep  5 10:06:52.742: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 659005
.Sep   5 10:06:52.746: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x10D5  callID = 0x9056 switch = primary-net5 interface = User
.Sep  5 10:06:52.746: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x10D5
        Standard = CCITT
.Sep  5 10:06:52.926: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x90D5
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#sh call hist voice brief
.Sep  5 10:06:57.738: ISDN Se0/2/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x90D5
ms. +  + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy  :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
Total call-legs: 10
KeyoCMErouter#
.Sep  5 10:07:00.546: ISDN Se0/2/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x90D5
.Sep  5 10:07:00.546: %ISDN-6-CONNECT: Interface Serial0/2/0:7 is now connected to 078XXXXXXXX N/A
.Sep  5 10:07:00.550: %ISDN-6-CONNECT: Interface Serial0/2/0:7 is now connected to 078XXXXXXXX N/A
.Sep  5 10:07:00.550: ISDN Se0/2/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x10D5
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
.Sep  5 10:07:05.818: %ISDN-6-CONNECT: Interface Serial0/2/0:7 is now connected to 078XXXXXXXX N/A
.Sep  5 10:07:05.818: %ISDN-6-DISCONNECT: Interface Serial0/2/0:7  disconnected from 078XXXXXXXX , call lasted 5 seconds
.Sep  5 10:07:05.818: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x10D5
    Cause i = 0x8090 - Normal call clearing
.Sep   5 10:07:05.822: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0   disconnected from 17XX747XXX , call lasted 31 secondssh call hist voice  brief
.Sep  5 10:07:05.826: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8001
.Sep  5 10:07:05.978: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x90D5
.Sep  5 10:07:05.982: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x10D5
.Sep  5 10:07:06.014: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0001
.Sep  5 10:07:06.014: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8001
ms. +  + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy  :
bw: / codec:
  tx:
rx:
Telephony call-legs: 14
SIP call-legs: 0
H323 call-legs: 0
Total call-legs: 14
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2EF  : 1573440 -387774992ms.21525 +18020 +23220 pid:20023  Answer 291
dur 00:00:05 tx:0/0 rx:255/40800 10  (normal call clearing (16))
Telephony 50/0/30 (1573440) [50/0/30.0] tx:5120/5120/0ms g711ulaw noise:0dBm acom:0dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a227A : 1573439 -387784732ms.21526 +1770 +32970 pid:20020  Originate 291
dur 00:00:31 tx:0/0 rx:413/66080 10  (normal call clearing (16))
Telephony 50/0/30 (1573439) [50/0/30.0] tx:4100/4100/0ms g711ulaw noise:0dBm acom:0dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a2EF  : 1573441 -387764592ms.21527 +7620 +13050 pid:12  Originate 078XXXXXXXX
dur 00:00:05 tx:255/42840 rx:259/41440 10  (normal call clearing (16))
Telephony 0/2/0:15 (1573441) [0/2/0.8] tx:5220/5220/0ms g711ulaw noise:-72dBm acom:47dBm
   long duration call detected:n long dur callduration :n/a  timestamp:n/a227A : 1573438 -387784752ms.21528 +1800 +33240 pid:10  Answer 017XX747XXX
dur 00:00:31 tx:413/69384 rx:1558/249280 10  (normal call clearing (16))
Telephony 0/2/0:15 (1573438) [0/2/0.1] tx:31210/31210/0ms g711ulaw noise:-75dBm acom:40dBm
asharsidd
More data - this time I captured sh call active voice brief.
YOu can see call legs were '0' in the beginning then it increased to '2' and then to '4' but then calls dropped.
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 0
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
.Sep  5 10:40:15.886: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
    Sending Complete
        Standard = CCITT
.Sep  5 10:40:15.890: ISDN Se0/2/0:15 Q931: Received SETUP  callref = 0x8001 callID = 0x10AA switch = primary-net5 interface = User sh call active voice brief
.Sep  5 10:40:15.918: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
.Sep  5 10:40:15.926: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8001
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Tele (callID) [channel_id] tx://ms noise: acom: i/o:/ dBm
Proxy :
bw: / codec:
  tx:
rx:
Telephony call-legs: 2
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
228B : 1573879 -385761632ms.1 +-1 pid:10 Answer 017XX747XXX connected
dur 00:00:00 tx:0/0 rx:0/0
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:0/0/0ms None noise:0 acom:0  i/0:0/0 dBm
228B : 1573880 -385761612ms.1 +-1 pid:20020 Originate 291 connecting
Tele 50/0/30 (1573880) [50/0/30.0] tx:0/0/0ms None noise:0 acom:0  i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#sh call active voice brief
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
.Sep  5 10:40:26.214: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8001
.Sep  5 10:40:26.278: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0001term
.Sep  5 10:40:26.278: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 17XX747XXX N/A
.Sep  5 10:40:26.282: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 17XX747XXX N/Alken
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#term lken         sh call active voice brief
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
228B : 1573879 -385761632ms.1 +10320 pid:10 Answer 017XX747XXX active
dur 00:00:07 tx:372/62496 rx:383/61280
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:0/0/0ms g711ulaw noise:0 acom:0  i/0:0/0 dBm
466  : 1573883 -385751382ms.1 +50 pid:20003 Originate 202 active
dur 00:00:07 tx:215/36980 rx:221/38012
Tele 50/0/3 (1573883) [50/0/3.0] tx:4300/4300/0ms g711ulaw noise:0 acom:0  i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
KeyoCMErouter#
.Sep  5 10:40:32.282: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 17XX747XXX N/A
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
Telephony call-legs: 3
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 3
dur 00:00:21 tx:924/155232 rx:1080/172800
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:16260/16260/0ms g711ulaw noise:-58 acom:45  i/0:-55/-32 dBm
dur 00:00:21 tx:715/122980 rx:721/124012
Tele 50/0/3 (1573883) [50/0/3.0] tx:14300/14300/0ms g711ulaw noise:0 acom:0  i/0:0/0 dBm
46A  : 1573884 -385732562ms.1 +-1 pid:20003 Answer 202 connected
Tele 50/0/3 (1573884) [50/0/3.0] tx:0/0/0ms None noise:0 acom:0  i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 3
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 3
dur 00:00:27 tx:930/156240 rx:1371/219360
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:21600/21600/0ms g711ulaw noise:-65 acom:45  i/0:-61/-65 dBm
dur 00:00:27 tx:715/122980 rx:721/124012
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 3
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
Telephony call-legs: 4
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 4
dur 00:00:32 tx:933/156744 rx:1634/261440
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:27430/27430/0ms g711ulaw noise:-73 acom:45  i/0:-69/-66 dBm
dur 00:00:32 tx:715/122980 rx:721/124012
46A  : 1573885 -385718882ms.1 +-1 pid:12 Originate 078XXXXXXXX connecting
Tele 0/2/0:15 (1573885) [0/2/0.8] tx:0/0/0ms None noise:0 acom:0  i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 4
KeyoCMErouter#
.Sep  5 10:40:58.446: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 01652659005
.Sep  5 10:40:58.446: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x10DB callID = 0x905C switch = primary-net5 interface = User
.Sep  5 10:40:58.450: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x10DB
        Standard = CCITT
.Sep  5 10:40:58.638: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x90DB
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 4
dur 00:00:37 tx:942/158256 rx:1885/301600
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:32690/32690/0ms g711ulaw noise:-73 acom:45  i/0:-73/-63 dBm
dur 00:00:37 tx:715/122980 rx:721/124012
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 4
KeyoCMErouter#
.Sep  5 10:41:03.374: ISDN Se0/2/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x90DB
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
.Sep  5 10:41:06.034: ISDN Se0/2/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x90DB
.Sep  5 10:41:06.038: %ISDN-6-CONNECT: Interface Serial0/2/0:7 is now connected to 078XXXXXXXX N/A
KeyoCMErouter#
KeyoCMErouter#
.Sep  5 10:41:06.042: ISDN Se0/2/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x10DB
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 4
dur 00:00:42 tx:948/159264 rx:2132/341120
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:37700/37700/0ms g711ulaw noise:-70 acom:45  i/0:-58/-65 dBm
dur 00:00:42 tx:715/122980 rx:721/124012
46A  : 1573884 -385732562ms.1 +21090 pid:20003 Answer 202 active
dur 00:00:02 tx:0/0 rx:0/0
Tele 50/0/3 (1573884) [50/0/3.0] tx:0/0/0ms g711ulaw noise:0 acom:0  i/0:0/0 dBm
46A  : 1573885 -385718882ms.1 +7400 pid:12 Originate 078XXXXXXXX active
dur 00:00:02 tx:139/23352 rx:141/22560
Tele 0/2/0:15 (1573885) [0/2/0.8] tx:2820/2820/0ms g711ulaw noise:-73 acom:53  i/0:-76/-22 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 4
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
dur 00:00:46 tx:951/159768 rx:2308/369280
Tele 0/2/0:15 (1573879) [0/2/0.1] tx:46190/46190/0ms g711ulaw noise:-71 acom:45  i/0:-69/-65 dBm
dur 00:00:06 tx:312/52416 rx:316/50560
Tele 0/2/0:15 (1573885) [0/2/0.8] tx:6340/6340/0ms g711ulaw noise:-67 acom:50  i/0:-65/-15 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
KeyoCMErouter#
.Sep  5 10:41:12.038: %ISDN-6-CONNECT: Interface Serial0/2/0:7 is now connected to 078XXXXXXXX N/A
.Sep  5 10:41:12.430: %ISDN-6-DISCONNECT: Interface Serial0/2/0:7  disconnected from 078XXXXXXXX , call lasted 6 seconds
.Sep  5 10:41:12.430: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x10DB
.Sep  5 10:41:12.434: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0  disconnected from 17XX747XXX , call lasted 46 seconds
.Sep  5 10:41:12.438: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8001
.Sep  5 10:41:12.594: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x90DB
.Sep  5 10:41:12.594: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x10DB
.Sep  5 10:41:12.630: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0001
.Sep  5 10:41:12.634: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8001
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 0
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
: ms. + pid:
IP : rtt:
  delay://ms
   last s dur:/s
  (payload size)
  (payload size)
Proxy :
bw: / codec:
  tx:
rx:
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 0
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#
KeyoCMErouter#exit
Can someone help please? Can this be due to a bug in 12.4(20)T1???
asharsidd
Can someone please shed some light on this issue?
asharsidd
So no one has come across this issue before? I can't buy that.
Someone must have resolved an issue like this before. Please help.
Hi Ashar,
I am eager to know how the issue was resolved. This can help other people.
was following corlist configuration the root cause of the problem ?
your incoming dial peer was not having the access to dial the outgoing dial peer ?
“If you have knowledge, let others light their candles in it.”
