Cant connect cisco cius dock station to external TV
KpaH4iTooo
Hello, I want to connect Cisco Cius that connected to dock station to external TV. I use exteranal HDMI TV that conneted to the dock station DisplayPort with HDMI to DisplayPort adapter. Dock station is powered with Power-cube-4. The usb mouse and usb keyboard are working good.
8 Replies 8
guille
Level 5
Level 5
I have exactly the same problem. I am using a Displayport-to-HDMI adapter Delock p/n 65091. Has anyone tested other adapters?
hi,
You need a SINGLE-LINK Display Port cable/adapter.
sollution here:
https://supportforums.cisco.com/thread/2114114
info
Those cables worked for me too.
Is there anything special that you needed to configure on your Cius to get this to work.  I got both
Accell B087B-005B UltraAV DisplayPort to DVI-D Single-Link Active Adapter ATI Certified
DisplayPort Male to HDMI cable Male
Plugged them in to the Cius Docking station and to our monitor, shutdown the cius and restarted with no pricture.
Any advice would be appreciated.  Thank you.
Rich,
Did your issues get resolved?
Shawn Eftink CCNA/CCDA Please rate all helpful posts and mark correct answers to assist others searching for solutions in the community.
You might want to ensure you disconnect power from the Media Station as well as restarting your Cius to ensure everything refreshes.
As well, make sure you're on the latest firmware which is 9.2.2(49).
You should see an icon at the top showing the cable connected, even when it isn't connected to any type of monitor.
Finally, check the HDMI settings, found in app center, to ensure HDMI connector status is enabled and Auto-Connect is enabled.
SHAWN EFTINK
Level 5
Level 5
I worked through this issue with Cisco and even though they wouldn't  "officially" state any supported cables, I did receive the following  information.  I order all 3 of these cables, tested them, and so far have not  had any further issues as these cables worked great!!
1. Accell B087B-005B UltraAV DisplayPort to DVI-D Single-Link Active Adapter  ATI Certified
http://www.amazon.com/Accell-B087B-005B-DisplayPort-Single-Link-Certified/dp/B004071ZX0/ref=sr_1_1?ie=UTF8&s=electronics&qid=1305786700&sr=8-1
2. Accell UltraAV B101B-003B Display Port with VGA Active Adapter
http://www.amazon.com/Accell-UltraAV-B101B-003B-Display-Adapter/dp/B003HC85D2/ref=sr_1_2?s=electronics&ie=UTF8&qid=1305787041&sr=1-2
3. DisplayPort Male to HDMI cable Male
http://www.amazon.com/High-Quality-Black-DisplayPort-Cable/dp/B002CSRF9M/ref=sr_1_4?s=electronics&ie=UTF8&qid=1305787184&sr=1-4
