ā02-11-2015 06:33 AM - edited ā03-17-2019 01:55 AM
Hello everyone!
We have a situation in a couple of our locations. They, unfortunately, have a T1 and ONLY a T1 @ 1.5Mbps ... inside they have about 10 phones...
whenever someone has a need to download a considerable sized file from the web or simply when ALL of them decide to do certain things at the same time, they eat up the 1.5 and then they start experiencing delays and issues with the calls.
Out QoS is configured like this:
class-map match-any call_signaling
match ip dscp af31
class-map match-any voice_media
match ip dscp ef
policy-map voip
class voice_media
priority percent 70
class call_signaling
bandwidth remaining percent 5
class class-default
priority percent 30
then the "voip" policy map is applied to the s0/0/0:0 interface which is their only means of communication. Phones are on VLAN 100 and computers on VLAN 1 native...
I was thinking that if I CAP the bandwidth for VLAN 1 to 1.25 Mbps, that would leave the rest for VLAN100 to use and not experience delays...
Is this viable? ... I don't know enough so I am asking is this the right way to do it... would it be better to modify QoS? would a combination insure neat non delayed calls every time?
Thank you for your help!!
Mario
Solved! Go to Solution.
ā02-11-2015 07:38 AM
First change your LLQ policy map to:
match ip dscp af31
match ip dscp cs3
āHow is the uplink port to the router on the switch configured?
ā02-11-2015 07:03 AM
QoS is meat to help in situations like this, sounds like your QoS policy is not working as expected.
Glancing at your config you are matching signaling on af31, most Cisco phones use CS3 so you should add that to your class.
How is your LAN policy configured?
Do you see packets matching when you issue "sh policy-map interface serial0/0/0"?
ā02-11-2015 07:34 AM
Thank you Chris for the response! ... Here is the output... yes we see matching packets and we really don't have a LAN policy, which I think is part of the problem (see all of this was done when I was hired) ... I am trying to adapt and change accordingly.. Below see a section of our switch and how it is configured as of now... again, THANKS!
Serial0/0/0:0
Service-policy output: voip
queue stats for all priority classes:
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 3004636/526541932
Class-map: voice_media (match-any)
1677943 packets, 256493034 bytes
30 second offered rate 200000 bps, drop rate 0 bps
Match: ip dscp ef (46)
30 second rate 200000 bps
Priority: 70% (1050 kbps), burst bytes 26250, b/w exceed drops: 0
Class-map: call_signaling (match-any)
92625 packets, 4911112 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: ip dscp af31 (26)
30 second rate 0 bps
Queueing
(pkts output/bytes output) 92625/4912136
bandwidth remaining 5% (0 kbps)
Class-map: class-default (match-any)
1310159 packets, 255876552 bytes
30 second offered rate 70000 bps, drop rate 0 bps
Match: any
Priority: 30% (450 kbps), burst bytes 11250, b/w exceed drops: 6413
auto qos srnd4
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
description Asha Kaul
switchport voice vlan 100
load-interval 30
mls qos trust dscp
storm-control broadcast level pps 80
storm-control action shutdown
spanning-tree portfast
match ip dscp af31
match ip dscp cs3
ā02-11-2015 07:47 AM
I did and also noticed different "ip precedence" values on the dial peers... so I also added cs1 , 2 and 3 ... and I am getting matching packets as well...
This is the port to the router from the switch:
interface GigabitEthernet1/0/24
description 2901 Router
switchport mode trunk
mls qos trust dscp
storm-control broadcast level pps 300
spanning-tree portfast trunk
Thanks!
