CAPF certificate expiration notification, Callmanager 8.6(2)
d.kleemann
Hi all,
our customer receive a notification on her Subscriber. Regenerate the Callmanager the certificate automatically or I have to generate these?
CTL-Client is not in use!
certmgr@LF101SW0245
Certificate expiration Notification:
                Certificate name: CAPF-9684f5a7.der
                Unit: CallManager-trust
                Type: own-cert
                Expiration: Fri May 17 22:03:32:000 CEST 2013 / Fri May 17 20:03:32:000 GMT 2013
certmgr@LF102SW0119
                Type: own-cert
Thanks for your help!
Daniel
Gordon Ross
Level 9
Level 9
You have to regenerate these manually and then delete the old ones. You'll keep on getting the alerts until you delete the old ones.
Make sure you have a good backup before you start !
I'd also recommend doing it out of hours. Changing the certs can cause your phones to reboot.
GTG
Please rate all helpful posts.
Thanks Gorden, what should I notice exactly ?
Brad Martin
Level 3
Level 3
I would also be interested in what to expect when regenerating certs. I am running 8.6.2 and the Callmanager.pem and ipset-trust certs are going to expire soon. Would like to know if there is any danger to ITL files on phones when regenerating the certs.
I was worried about that, too. But I didn't get any problems with ITL files.
GTG
