CAR CDR Analysis and Reporting
p.horwood
I am running CUCM 7.1.2a
On trying to run certain CAR reports namely any device reports/ Route plan - Route Pattern reports
I get the error
Error Code
Error Description
10011
System Error. Contact System Administrator.
All other reports seem to work.
I also see that other people have had this problem on other versions of  CUCM.
Any ideas anyone
7 Replies 7
lusandi
I hope this can help you.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080933fcf.shtml#problem1
If you need something else please let me know.
Hi Luis,
Nice find here (+5 points for this good work)
Cheers!
Rob
I'll give it a try today. As Rob says a great spot
Paul Horwood
Sadly I tried all 4 solutions and none of them worked
Paul Horwood
Rob Huffman
Hey Paul,
It looks like this bug
CSCsz46571 Bug Details Bug #16 of 72 | < Previous | Next >
CDR: PDF Route Pattern utilization report fails with 10011 System Error
Symptom:
Unable to generate PDF reports for Device Reports -> Route Plan -> Route Pattern/Hunt Pilot Utilization. The following error message is displayed:
"10011  System Error. Contact System Administrator."
Workaround:
Instead of generating a PDF report, generate a CSV report
Status
Fixed
Severity
3 - moderate
Last Modified
In Last Year
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
7.0(2)
Fixed-In
7.1(2.39000.38)
7.0(2.21017.1)
7.1(2.21001.1)
7.1(3.10000.11)
Hope this helps!
Rob
lusandi
I would like to confirm whit you if you can create the csv files?
or you just can not create the reports?
I will be waiting for the information.
Luis,
User Reports, System Reports and searching the CDR all work and that includes csv and pdf. My problem is I cannot get the Device reports to work namely Route List/Group Route Pattern Utilization
Paul
0131 448 4988
