Carrier Dedicated Voicemail Issue fro PRI on CME
prabhu050446
Hello Guys,
I am new to voice, basically a routing switching guy. I have a phone that has Dedicated DID 877 from PRI and a dedicated voice mail number 800xxxxxxx from carrier.
We have main phone which is 872.
Issue is when I call 877 phone from my office phone or cell if the call is not answered it goes to voicemail number 800xxxxxxx but when I hear the voicemail it says the source is MAIN phone number not my cell or office #.
Below is the config. Can you please help me out here.
Thank you in advance.
voice register dn  50
 number 7080
 call-forward b2bua noan 91800xxxxxxx timeout 15 <<<<<<VOICEMAIL #>>>>>>>
 allow watch
 name Call Center 7080
 label Call Center 7080
voice register pool  50
 id mac 0004.xxxx.xxxx
 type P600
 number 1 dn 50
 template 1
 dtmf-relay rtp-nte
 username 7080 password xxxxxxx
 codec g711ulaw
voice translation-rule 1
 rule 1 /^7080$/ /xxxxxxx877/ <<<<<<<PHONE 1>>>>>>>>>>>>
 rule 15 /.+/ /xxxxxxx872/ <<<<<<<<<<<MAIN PHONE>>>>>>>>>>>
voice translation-rule 2
 rule 1 /^7080$/ /xxxxxxx877/ <<<<<<<<<PHONE 1>>>>>>>>>>
voice translation-profile 1
 translate calling 1
voice translation-profile RedirectFull
 translate redirect-called 2
dial-peer voice 9180000 pots
 description 800 Calls
 translation-profile outgoing RedirectFull
 destination-pattern 91800.......$
 port 0/0/0:23
 forward-digits 11
dial-peer voice 9186600 pots
 description 866 Calls
 destination-pattern 91866.......$
 port 0/0/0:23
 forward-digits 11
dial-peer voice 9188800 pots
 description 888 Calls
 destination-pattern 91888.......$
 port 0/0/0:23
 forward-digits 11
dial-peer voice 9184400 pots
 description 844 Calls
 destination-pattern 91844.......$
 port 0/0/0:23
 forward-digits 11
num-exp x877 7080
prabhu050446
Adding more details.
voice-port 0/0/0:23
translation-profile outgoing 1
I know it is getting MAIN PHONE number 572 as source for voice mail because of the above port configuration with trans-prof outgoing 1. but not sure how to have source as 577 instead of 572.
Thank you
To start with, if you are sending the voicemail to outside, its not best
practice to send the original calling number. The provider might overwrite
it as this isn't what they are expecting as calling number for outgoing
calls. They might also block the call. Unless its sent as redirect IE.
In your case, since its overwritten by main, then the calling number isn't
sent as redirect IE. You can confirm this as well using debug isdn q931
Create a separate pots dialpeer with destination as your voicemail and
don't manipulate digits on this dialpeer. Then move your translation from
voiceport to other outgoing dialpeers. Its a duplicate work.
If this didn't fix the problem and you still get the main, then your
provider is overwriting the calling number with PRI pilot number
