08-10-2010 05:17 AM - edited 03-16-2019 12:09 AM
Please suggest me solution for the error "Backup initiation timed out. Master agent might still be processing this operation or may be down. Please check 'Backup->Current Status' for latest status." Whenever i click on manual backup it takes time and shows me this error and when i refresh the page and go to Current Status it shows " No backup status available" . Due to this i am not able to take backup of Call Manager. I have Restarted Cisco Tomcat, DRF Local and DRF Master Services. But didnt work.
Please reply if anyone know the solution..
08-10-2010 05:31 AM
Hi Rosy,
You may be hitting this bug;
Cheers!
Rob
08-10-2010 10:13 PM
Thank you Mr. Rob for sharing information, as i just want to know more that is there any solution instead to upgrade to next version. Because if nothing left to this Version only then i can initialize change to my upper level to upgrade. So, as you said is there any solution can work in this matter? As i said i have started Cisco Tomcat Service and restarted DRF Master and Local Service.
