CCM 6.1.2, HP tools for monitoring.
rohanpatel
I am install CCM 6.1.2 and the I have HP servers. Is there any way I can install HP tools on the Linux boxes.If you, how can I do it and is it a best practise?
Thanks!
gogasca
Level 10
Level 10
Technically you can, not supported we have other third party monitoring tools, that should work
Root access required
Thanks...
So If I want to install I need to contact TAC
and get the root access or it there any other
way to do it.
Thanks!
