Which CM server to buy
rcrumm_2
Level 2
Level 2
I believe we are suppose to buy a CM server based on points for end points, but I can't find that anywhere.
Is this the correct way in determining the right servers to but and where do I find this info?
Randall
Rob Huffman
Hi Randall,
Here are two good reference docs for this type of planning. It's always a good idea to engage your Cisco SE in this process as they have access to this good tool (you may be able to get it from TAC as well);
The Cisco Unified CM Capacity Tool
Unified CM Platform Capacity Planning
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/callpros.html#wp1043871
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Jaime Valencia
read the call processing section from the appropriate SRND to get more information on this. it discusses all that info
java
if this helps, please rate
java
