CCM 9.1 Unrestricted Verison
Scott Beauton
I'm going to be installing CCM 9.1 in a new cluster in the UK.   Since it's US Export I was going to make sure that CCM is unrestricted.   Is there seperate media for CCM9.1 unrestrcited or do I just have to install 9.1 and then apply a patch to make it unrestrcited.   I can't find any part numbers for differernt media for CCM9.1 unrestricted so didn't ' know if anyone could assit.  Thanks   in advance
Hi Scott,
For most of the countries excluding  (Sudan, Cuba, North Korea, Syria, Iran) you can have restricted version. Depending on your location you may not need export license.
For UK you can have restricted version without need for any export license, see below links. I would recommend you install the normal restricted version.
http://www.cisco.com/web/about/doing_business/legal/global_export_trade/general_export/contract_compliance.html
http://www.cisco.com/wwl/export/faq.html
GOVERNMENT - RESTRICTED ENCRYPTION
Government entities not located in the countries listed below would require US export license in order to obtain restricted encryption items. Please see Cisco's license application at http://www.cisco.com/wwl/export/forms/form_license.html .
Austria, Australia, Belgium, Canada, Czech Republic, Cyprus, Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Ireland, Italy, Japan, Latvia, Lithuania, Luxembourg, Malta, Netherlands, New Zealand, Norway, Poland, Portugal, Slovakia, Slovenia, Spain, Sweden, Switzerland, United Kingdom, United States.
Un-restricted version will have two drawbacks:
1)      Encryption will be turned off
2)      You will never be able to migrate back to restricted version in future on a system that had unrestricted version. (http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/9_1_1/CUCM_BK_R6F8DBD4_00_release-notes-for-cucm-91_chapter_01.html#CUCM_TP_U83A2DF7_00
Terry
5 Replies 5
Dennis Mink
Scott,
you cant go from restricted to unrestricted, not even with a patch.  So get the unrestricted media, or download it from CCO. (you can make the images bootable otherwise you will need to order them).
Hope this helps
Please remember to rate useful posts, by clicking on the stars below.
Thanks minkdennis for your reply.  Yes I know how to make a bootable ISO but techinally this is not supported by Cisco TAC. Besides this post, I don't know how Cisco TAC will know that I didn't use orginal media but I've heard that there is a way to tell.   Just saying.  Thanks.
Hi Scott,
Terry
Thanks Terry.  I was searching all afternoon for what coutries are supported for restricted verison.   That really helps out a lot.  Thanks
Not a problem Scott - Glad that helped.
Terry
