02-11-2007 08:55 AM - edited 03-14-2019 07:58 PM
In reading the release notes for the DST 2007 Update (http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/crypto/3DES/voice/callmgr/4.1/ciscocm.4-1-3-2007-DST-Update.1-0-1-readme.htm&app=Tablebuild&status=showC2A) it says "Step 4: The Publisher will be rebooted at the completion of install. After the Publisher is back up, each server in the cluster must be rebooted in a sequential fashion, starting with the TFTP server and backup CCM Servers.". Just to be clear, you do NOT need to install the update on any Subscriber, TFTP server...etc, just reboot them after it has been installed on the Publisher? Thanks!
Solved! Go to Solution.
02-16-2007 04:47 PM
Thanks Mike for your prompt response !!! so you were referring to the new phone load for 7960s and 7940s phone that came with CCM 4.1.3 . it's not a separte patch
Thanks again !!
Danny
02-16-2007 10:13 PM
The 8.0.5 phone load is a seperate update. Only takes 30 seconds to install and doesn't need a reboot.
