CCM web page
user-cisco
i'm sorry for this silly question, but i wonder if i can access callmanager web admin page directly bypassing the website's security certificate
iam asking this because i'll send my users a link to ccmuser page so that they can change their passwords and PIN and change other device settings ..
does any body has any idea
thx
6 Replies 6
Jaime Valencia
starting with CCM 4.1(3) all releases use https for security and cannot be disabled
java
if this helps, please rate
java
thanks java for ur response actually i was wondering whether i could install a SSL certificate on the CCM web server to bypass the certificate error messages when my users access user web page to change user options
can u help plz
did u ever get an answer for this? I just want to do it for the ccmuser page.
Not sure about your particular Call Manager version.
I believe this is possible to install a third party certificate so you dont get the security warning. I referred to a Call Manager version 6.1.2 in my case.
Cisco Unified OS Administration - Security - Certificate Management
You can click on "Help for this page" to learn more
There is also a bit of information in the Administration Guide as well as the release notes.
Hope that helps.
Thanks....I will check this out.
I am using ccm4.1.3
My mistake. 4.1.3 does not have this page.
