CCM5.x - Linux OS - ip 7970 Phone background wallpaper ?
muarrij
Hi, I have changed the background image on 7970 phones that used CCM 4.x but im not sure how to do this on the CCM5.x (Linux OS) based systems. Can anyone help?
Jaime Valencia
try the instructions from this link:
Creating Custom Background Images
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7970g_7971g-ge/english/5_1/sip/english/adminstraton/guide/7970cst.html#wp1088046
the config is case sensitive so make sure to create the folder and name the files under List.xml as they show up in your windows explorer
java
if this helps, please rate
My TFTP/Publisher server is hosted on the Linux based appliance, version 5.x. This document is geared towards the windows version, which was much easier to configure. Does anyone know where to put the List.xml file on these systems? The phones currently point to the Publisher/TFTP.
Look at the title from the DOC i sent you, it's for CUCM 5.1, not for windows based platforms
here's the process for uploading TFTP files
Uploading TFTP Server Files
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/5_1_1/iptpch7.html#wp1017196
follow the instructions from the 1st doc and use the above one to upload the files
java
