ccme 4.2 upgrade call failure h323
jaimebautista
Guys I just upgrade a Cisco 2851 router with ccme 4.2 (c2800nm-advipservicesk9-mz.124-11.XW10.bin) (cme-124-11XW2) and now I can't establish calls from ATA 188(h323) nodes to the Main Site(2851). When I try to call from an ATA of a remote site to the Main site (7940); the phone at the main site only rings ones and goes into fast busy.
I'm getting the following message from the debug call command.
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
May 10 01:30:39.443: //6257/FFFFFFFF080A/CCAPI/ccCallDisconnect:
   Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
Below is how the system is setup.
a.)  MainSite(2851) <-- h323--> Node(ATA). Call established
      Node(ATA) <-- h323-->MainSite(2851). Call established
      Node (h323) <--h323--> Node(ATA). Call Established
After the upgrade:
     Node(ATA) <-- h323-->MainSite(2851). Call Fails
I'm using codec g729r8 at the main site Voip dial peers and LBRCodec (3), RXcodec(3), TXCodec (3) on the ATAs.
All these sites are connected through VPN DMVPN and EIGRP(Routing).
Note: I was previously running CME 3.3
Thank You,
Jaime
Logan Gaffney
Cause Code 41 is just temp fail, nothing to specific.  Can you get the following debugs for a failed call on the Main GW:
debug h225 asn1
debug h245 asn1
debug voip ccapi inout
Please indicate the calling and called number and attach a "show run".  Thanks!
***Please rate helpful posts
Hi Logan,
The Calling number is 1112 and called number is 1090. I've attached the debug and show run.
Can you please try the following:
conf t
voice serv voip
no supplementary-service h450.12
Test again.
The phone doesn't ring when I disable supplementary-service h450.12. Any other suggestions?
Thank you
