CCME 7.0 support to IPMA
wilsonsant
Level 6
Level 6
Hi Guys,
I would like know if CCME version 7.0 x have support to service manager assistant or assistant console.
Wilson
Jaime Valencia
IPMA is a CUCM feature, not CME.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Javalenc,
Thanks for Your information. I have following doubt: the manager assistant and assistant console is the same thing?
Thank You,
Wilson
