ccme: max # of conference
lampard1398
Dear all,
I add the following command on ccme but i can only made a conference call with three user at a time from my 7941 phone.
telephony-service
max-conferences 8 gain -6
Any other config is required to make conference call with more than 3 users.
Thanks.
35 Replies 35
What problem you faced exactly ? Are you using CME? If so, pls send output of "show dsp dspfarm".
It is CME.
I found a document says that CME doesn't support dsp-based conference profiles.
I doubt it NOT supporting MTP (s/W & H/W) also.
Not sure which document are you talking about.
If you read the "CME administrator guide", latest version it will tell you how to configure multi-party conferences, meet-me and ad-hoc. Both are DSP-based by the dspfaarm in the same router.
Also please explain what problem are you trying to solve with MTP.
The document is GWGK cisco press August 17,2006
under Part || chapter 4 DSP resources.
I faced the same problem in CME 4.0(0)
Regarding software MTP it is not registered to CME.
Regarding hardware MTP also maximum sessions is 0
Pls upgrade to cme 4.1 w/ IOS 12.4(11)XJ4 and you will have all the conferencing options.
I'm concentrating on 3.3 cause it is in the exam.
Does it support h/w MTP?
I tried s/w MTP & got the following when type"sh sccp all":
Mar 1 08:22:32.033: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x646B5B68 -Process= "Skinny
Socket Server", ipl= 0, pid= 207 -Traceback= 0x6043A50C 0x60675160 0x6067949C 0x6074DA94 0
x60750904 0x60754C6C 0x61E92434 0x61E92EA8 0x60537B14 0x60537AF8
Mar 1 08:22:32.041: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x646B5B68 -Process= "Skinny
x60750884 0x60754C6C 0x61E92458 0x61E92EA8 0x60537B14 0x60537AF8
x607508A0 0x60754C6C 0x61E92458 0x61E92EA8 0x60537B14 0x60537AF8
x60754C7C 0x61E9247C 0x61E92EA8 0x60537B14 0x60537AF8
Software MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: NOT_REGIS_WITH_CCM
Active Call Manager: 192.168.100.1, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 6
Reported Max Streams: 20, Reported Max OOS Streams: 0
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30"
What is the problem??
