CCME Router Choice
angel-moon
Level 3
Level 3
                   All,
if posed with a choice between a 2825 and a 3825 router, both running CCME and both also destined for a VPN termination device as well as the Internet router which would be the better choice given about 25 users from 3 different sites. 15 at the main site and the 5 users at 2 remote sites.
Thanks in advance.  all replies rated.
Chris Deren
I take it you mean 2821 not 2825, Obviously 3825 is more powerful but also more expensive and an overkill for what you are describing, so 2821 would be just fine.  Keep in mind that you should be looking at ISR G2, i.e 2921, 3925 not 28/38XX as those have been EOS for a while, if this is new implementation.
HTH,
Chris
Chris Deren
HTH,
Chris
