Hello all,
I have a question regarding unanswered calls in the CDR records. Sometimes they do show up, other times they don't.
Any light on how CUCM decides to create a record or not is welcome ...
Cheers,
Jan.
Solved! Go to Solution.
I think you should activate the CDR Calls with zero duration, in order
to log "not connected calls"
Extract from CUCM Help :
CDR Log Calls with Zero Duration Flag: This parameter enables or
disables the logging of call detail records (CDRs) for calls that never
connected or that lasted less than 1 second. Cisco CallManager logs
unsuccessful calls (calls that result in reorder, such as might occur
due to a forwarding directive failure or calls that attempt to go
through a busy trunk) regardless of this flag setting.
haha, indeed, gotta love the service parameter section ;-)
Thx mate,
Jan.
