CDR Date & Time conversion
mightyking
Level 6
Level 6
Hello All,
How can I convert the date & time in the CDR report to underestandable date and time? There used to be a tool for this matter, does anyone have that tool?
19 Replies 19
you can translate the timestamp with this method:
1.Put the timestamp in cell a1.
2.In cell a2, enter =a1/86400+25569.
3.To apply a new format to this cell, right-click and choose Format cells >
Numbers > Custom. In the Type field, enter dd:mmm:yyyy hh:mm.
The output looks like this: 04 Apr 2001, 13:57
Firdaush
many many thanks!!!
jmoreno@IBM
UNIX Timestamp:
I know... Decade old issue, but here is the answer.
Do this in Excel:
  1. Use this equation in a separate column.  =(((E2+(-8*3600))/86400)+25569)
    • E2 is our first cell of original CDR Date time. [Ex: 1520230703]
    • -8 is the Time Offset. I entered -8 to convert to PT.
    • 3600 is seconds in each hour.
    • 86400 is seconds in each day.
    • 25569 is because spreadsheet counts epoch from 1/1/1900 and most others start at 1/1/1970.
  2. Press ENTER [on your keyboard]. Cell value should look something like this: 43164.5961.
  3. Highlight new column or cell, right-click, and select Format Cells...
  4. Use TIME or DATE format of your choosing.
Thank a lot for sharing the right information.
Thanks a lot for sharing right information.
