CDR Error 10021: There are no matching records - Cisco 11.5
LPSHelpdesk
Hey Guys
Just trying to get CDR Search by Phone going however when ever i try run that report i get error 10021
We have both a subscriber and publisher server.
Any tips of where i should be looking to resolve this? I have seen some older threads
https://supportforums.cisco.com/discussion/11268786/cdr-reporting-code-error-10021
how ever when ever i check in CM administration under system>service perameters> i dont have a have an option for CDR
Any idea?
Cheers
Manish Gogna
Looks like you don't have the complete config in place for CDR, first please complete it as per the following doc
https://supportforums.cisco.com/document/53056/understanding-cdr-call-detail-records#Configuration
Then specific to the above error you can follow the instructions from the following troubleshooting guides if the issue persists
https://supportforums.cisco.com/document/55821/troubleshooting-cdr
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-50/100465-cdr-cmr-error.html#Problem2
Manish
Thank you so much, i will double check over everything!
