IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5434 Views
  • 14 replies
Hello, I'm having intermittent issues with hookswitch between CP-7841s and Jabra Pro 9470 headsets.  If the headset is undocked and being worn when a call comes in, and you answer the call from the 7841 you do not get the call in the headset for upw...
hello guys,  i need your help!! My boss ask to me to study the combination of nat, voip and routing, so i need to create a scenario as in attached topology. My big problem is to use THE SAME addresses in both the networks. i've to be able to give uni...
Andrea_83 by Level 1
  • 235 Views
  • 3 replies
