04-17-2013 06:46 AM - edited 03-16-2019 04:51 PM
I have recently upgraded our CUCM to ver 9.1.1 from 8.6.
I use PRI and only receive the last 4 digits from the telco. When receiving inbound calls I send them to Unity Connections VM Pilot DN 2050.
So a PRI call comes DN 2401 and then immediately transfers to VM 2050 to hear greeting and then customer can hear greetings and chooses an option.
RAW CDR are then sent off to Infortel Cisco Report server. Listed below is output from the RAW CDR:
CUCM - 9.1.1
originalCalledPartyNumber finalCalledPartyNumber
2401 2050
Before upgrading the CDR used to be which worked within Infortel report server.
CUCM - 8.6.2
2401 2401
Does anyone know how to make a change so the bottom example would be the working config?
04-17-2013 09:01 AM
Hi there,
I'm just wondering if you weren't actually seeing this 8.6 bug;
Maybe time for a TAC case
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
03-05-2018 05:25 AM
Got any solution for above mentioned issue ? Because in my case, Pilot number is the final called party number in CDR. Then how to know who answered the call?
