CDR load to SFTP server at midnight
I just want to know that is there any option that i can change so that my CDR should get loaded to SFTP server at mid-night.
However i changed the Enterprise parameter to generate a CDR file for 24 hrs by changing the enterprise parameter in CUCM to 7:00PM.
I requirement is that i need to transfer the file to SFTP server in mid-night 00:00.
Any help is appreceiated.
Jaime Valencia
There is no specific timer for this, the only thing I could think of, is to  restart the CDR services at midnight. Not sure if that will work.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I think by default the CDR service restart at mid-night only.
It will be great if you can confirm on it.
I tried restrting the service but still the file is coming on regular hour not the time when i restarted the service.
Plkz let me know what else can be done to acheive the goal.
Ru[pam
That was pretty much the only option, there is no way to configure the time at which the file is sent.
There are no settings to control this.
java
java
