centralize dial Plan For Multi-Site
ahmedtallat
we are implementing Cisco IP Telephony for our Company
we have around 20 remote Site, we will install in these sites CME and in the HQ will install CUCM
is there any way to do centralize dialing plan ? our we need to make SIP trunk between each sites
thanks for help
Manish Gogna
Hi Ahmed,
Because the remote sites will have the phones registered to CME so in this case they will use the dial plan configured on respective CME.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/9x/uc9x/dialplan.html
Manish
heathrw
Level 4
Level 4
Edit: As mgogna  stated each site will need their own dial plan but if you are wanting dialling between branches you could try looking at using Service Advertisement Framework (SAF) which is often compared to a routing protocol for dial plan where the call control system advertises its own dial plan to other call control systems.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/9x/uc9x/models.html#wpxref73275
You can also use Call Manager Session Manager Edition which is a centralised aggregation for SIP trunks which can also provide more flexibility than the SAF
Just comes down to your requirements such as site to site dialling, least cost routing, etc
Please rate helpful posts.
Hi heathrw
Thank you for your replay, what do i need to Make SAF network? it's Router having all these information ? is this feature same like making a gatekeeper ?
if we go to Call Manager Session Manager Edition, we can install it in one of the HQ UCS server ?
thanks again
