CF1 LED appears to have died as no longer luminates
John Cheetley
Level 3
Level 3
Hi Again Cisco techs,
Following Jaime Valencias suggestion to upgrade my CME for SIP. Looked at the CME and IOS matrix
CME 7.1 is chosen one and is 41mb basic
My external CF1 slot0 appears to have died as the LED for this no longer luminates with compact flash inside
Troubleshooting proves below
cme_router#sh file system
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
           -           -    opaque     rw   archive:
           -           -    opaque     rw   system:
       57336       48655     nvram     rw   nvram:
           -           -    opaque     rw   null:
           -           -   network     rw   tftp:
*   32047100      397360     flash     rw   flash:
           -           -     flash     rw   slot0:
           -           -    opaque     wo   syslog:
           -           -    opaque     rw   xmodem:
           -           -    opaque     rw   ymodem:
           -           -   network     rw   rcp:
           -           -   network     rw   pram:
           -           -   network     rw   ftp:
           -           -   network     rw   http:
           -           -   network     rw   scp:
           -           -   network     rw   https:
           -           -    opaque     ro   cns:
With slot0 empty (no compact flash inside)
cme_router#format slot0:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "slot0:".  Continue? [confirm]
Enter volume ID (up to 64 chars)[default slot0]:
%Error formatting slot0 (No device available)
cme_router#
Containing compact flash is the same
And show inventory output
cme_router#sh inventory
NAME: "2691 chassis", DESCR: "2691 chassis"
PID:                   , VID: 0.1, SN: JMX0642L246
NAME: "Wan Interface Card BRI S/T (2186)", DESCR: "Wan Interface Card BRI S/T (2186)"
PID: WIC-1B-S/T=       , VID: 1.3, SN: 32341361
NAME: "One port E1 voice interface daughtercard", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1=     , VID: 1.0, SN: 31525479
NAME: "MARs 2 port Voice PM", DESCR: "MARs 2 port Voice PM"
PID: NM-1V=            , VID: 1.1, SN: 15648337
NAME: "Two port DID voice interface daughtercard", DESCR: "Two port DID voice interface daughtercard"
PID: VIC-2DID=         , VID: 1.0, SN: 32808181
show hardware output
Cisco 2691 (R7000) processor (revision 0.1) with 118784K/12288K bytes of memory.
Processor board ID JMX0642L246
R7000 CPU at 160MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
2 FastEthernet interfaces
1 ISDN Basic Rate interface
1 Channelized E1/PRI port
2 Voice DID interfaces
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of NVRAM.
31296K bytes of ATA System CompactFlash (Read/Write)
0K bytes of ATA Slot0 CompactFlash (Read/Write)
I don't suppose the slot0 is IOS based?
Any suggestions please?
Wilson Samuel
Level 7
Level 7
I am not sure if have seen any 2600XM in a long time, let alone 2600 (2600 were End of Sale about in 2003)
I think the best option would be to upgrade the router to atleast 2900 series router.
there are so many vendors who deal Cisco routers these days (esp if you are in the USA) that is should be very easy
