03-01-2009 08:30 PM - edited 03-15-2019 04:32 PM
hi,
i have a strange problem, ccm v4.1.3(sr5b), i deleted all tracks on one DID. but still the old CFNA/CFB settings are working for that DID in ccm.
Is this DID records are not still deleted from ccm, i checked route plan report, but that did not listed there.
Any clues!!!!
Solved! Go to Solution.
03-03-2009 10:17 PM
dear can u please tell me which trace should i look into more specifically
03-04-2009 07:38 AM
already did, "CUCM trace"
java
if this helps, please rate
