IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6162 Views
  • 14 replies
Hi,This be a noddy question, but the SRND mentions the following -The Cisco Unified IP Phones 7902G, 7905G, 7910G, 7910G+SW, and 7912G are no longer availablefor sale, but they are still supported by Cisco Unified Communications Manager 7.x.It does n...
Resolved! Strange Fax Issue
I have a translation pattern xlat'ing a DID # to an external fax # with the called party transform mask set to 9xxxxxxxxxx (local # so no preceding 1 is necessary). Doubt it matters but the fax machine is in the same physical location as the gateway...
Hello,I've successfuly installed CM6.1.2 on new hardware (while leaving existing pub/sub intact)using dma and registered the lics. How do i start using the new server? I tried changing the ip address on one of my 7940's to point to the new server w...
ctcopsmde by Level 1
  • 441 Views
  • 4 replies
Hello,On CUCM 6, when my users want to access the user page, they should type http://ipaddress/ccmuser, but in CUCM 4.1 i was redirectng just the ip address directly to this link so it was much easier for them to access the page. How can I do this in...
