Change a Route Pattern to Redirect to External Number
Brandon Feemster
Beginner
Beginner
I have a phone number that is setup as a Route Pattern so that calls to that number are directed to a Fax server. I need to change it so that calls to that number now get forwarded to an external phone number. What would be the easiest way to do this?
Thanks in advance.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Use a translation pattern
java
if this helps, please rate
Jaime Valencia
java
Recognize Your Peers
