Change Cisco 8851 UI Color
Ricky D
Hello everyone,
What's the process for changing the UI on our 8851s? We are looking to move from the black bottom bar to the white.
Slavik Bialik
Level 7
Level 7
The only thing you need is to upgrade the firmware of the phones to the newest one.
The new UI (the white one) is introduced from firmware version 11-5 if I'm not mistaken, but today you have 12-1, so you can install it. Just download from here:
https://software.cisco.com/download/home/286255328/type/282074288/release/12.1%25281%2529
Jaime Valencia
AFAIK that's not configurable, if it changes, most likely is due to a FW version that has that.
java
if this helps, please rate
Slavik Bialik
Level 7
Level 7
Sure enough this was it! Got it upgraded to 12-1 per the instructions. I appreciate it!
