Showing results forĀ
Search instead forĀ
Did you mean:Ā
Change Language Conversation Sign-In Unity
christianbernal
Good day!!
One question, I need changed the language for Attempt Sign-In in one Cisco Unity Connection, I have one Cluster version 11.0, I try install  cm-locale-es_CO-11.0.1.1000-1.cop.sgn and  some audios changed, but when the users need digit the PIN the audio it sounds in English, this is the configuration:
How I can changed the conversation "Attempt Sign-In" to Spanish ??
Thanks ...
Nirmal Issac
Hi Christian,
Please check the configuration in the below setting.
User settings > Edit > Message Settings > Language That Callers Hear >
Please choose the language as Spanish.
Also, please confirm if the Conversation Manager and Mixer services were restarted after you uploaded the locale.
Nirmal Issac
Hi Christian,
Hi Nirmal,
Yes the error was the configuration in the user template.
Thanks.
