Changing Callmanager Manager Administrator password
aslam.bajwa
Level 3
Level 3
Hello All ,
can we change callmanager admin password and username , as our auditor requested to change this username and password . we have three nodes in the cluster . any risk involed in it .
regards ,
Aslam
Tapan Dutt
Yes you can change the administrator user name and password using SSH session.
Login to an SSH into the node*(for which you'd like to change it) and type in the following command:
utils reset_ui_administrator_name
it will prompt you to enter a new name
then use
utils reset_ui_administrator_password
it will ask you for the new password
Enter and its done
Tapan
