Video & Inter Cluster Trunk
Gordon Ross
Level 9
Level 9
I have an ICT between two 8.03 clusters. Within each cluster video calls between handsets works fine.
Across the trunk, I only get audio.
What am I missing ? I thought ICTs were supposed to support video.
GTG
Please rate all helpful posts.
Marwan ALshawi
Try to use SIP trunk instead of ict
Also check the device pools of the trunks and devices interns of locations/allowed video bandwidth
It was the bandwidth issue on the locations. Video works fine over an ICT.
Need to go and re-read the manaul on locations & bandwidth now....
GTG
glad to know that
make sure your rate the helpful post
