Changing Dial Tone on CUCM 8.0
albertochavez
A customer asked if it is possible to change the dial tone that the IP Phones generate when going Off-Hook. They somehow need it to be with a less frequency.
We are using the Spanish (Colombia) Locale, as it's our regional locale since we are in Venezuela. Do we have to switch locales in order to get a different dial tone or is there a way to change it?
Thanks in advanced.
Best regards,
Alberto Chavez
2 Accepted Solutions
phooghen
Dial tone is locale specific.
If you want to change the dial tone, you probably need to change the locale.
Pierre.
nitsinha
Level 4
Level 4
Network locale in specific needs to be changed for this.
Hope that helps
Nitesh
phooghen
Pierre.
nitsinha
Level 4
Level 4
Hope that helps
Nitesh
Thanks both of you for your help
