Changing Display Name in CISCO CME IP Phones
I tried changing the Phone Display name by Changing the Description in the Voice Register Pool and reset the phone, but the display name remains same. Any Idea why? I also want to add 2-3 more CISCO Phones?
below commands are enough for adding a new extension or am I missing anything?
Router> enable
Router# configure terminal
Router (config)# voice register global
Voice register dn 1
Number 501
Name Test
No-reg
Voice register pool 1
Id mac xxxx.xxxx.xxxx
Description Test
Number 1 dn 1
Type 7841
That won’t effect your working environment.After issuing the command restart the phone.
Do restart  from voice registrar pool. Or From phone manually remove the network cable and plug it back.
Response Signature
8 Replies 8
You need to do that under voice register dn
Example
voice register dn 15
name testuser
Then go to voice register global
create profile
Description is different thing.
Example Cme configuration.
voice service voip
no ip address trusted authenticate>> enable this and add your ip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
registrar server
mode cme
source-address 192.168.1.50 port 5060
timeouts interdigit 5
max-dn 100
max-pool 100
load 7841 sip78xx.12-8-1-0001-455
load 8841 sip88xx.12-7-1-0001-393
load 8851 sip88xx.12-7-1-0001-393
olsontimezone Asia/Muscat version 2018e
timezone 34
date-format D/M/Y
create profile sync 241824305502345A
auto-register
voice register dn 1
number 101
pickup-group 1
name Desk
label  Desk
voice register pool 1
busy-trigger-per-button 2
id mac 7802.B179.17D8
type 8841
number 1 dn 1
template 1
dtmf-relay rtp-nte sip-kpml
voice-class codec 1
Response Signature
Thanks for the detailed reply. Just to confirm, is it safe to apply the create profile command on a live environment? will it affect any other configuration?
It’s safe to apply create profile on live.
Response Signature
Ok. Thanks. I did change the voice dn name also, but didn't Run Create Profile, in fact I am bit scared to give this command. Is safe to run this on working environment, will it affect the live phones?
It should be safe to run that command.
Response Signature
Response Signature
Thanks. Just one more thing, I must apply the CREATE PROFILE after adding new extensions, right?
After making changes or adding new  things you need to  do create profile. Changes means adding new extension, modifying  extension, changing names, changing label etc..
Response Signature
