changing image in ccm authentication page
Gilberto Marcos
Hello.  I am wondering if someone has done this before. My customer is asking me to change the authentication call manager page. They want to see their enterprise logo instead of the image that cisco call manager shows.
5 Replies 5
Tommer Catlin
I believe i 8.5 you can add a logo or company name at the login page.
Joseph Martini
You can add a banner, but you cannot add a customized logo:
https://supportforums.cisco.com/docs/DOC-5952
Matt Barber
Hey,
I have been playing around with the feature this morning and found it accepts IMG tags in the banner file that you can upload. So even though you can't change the top left image, you can insert a company logo in the banner itself.
For instance, I created this banner file:
http://10.48.55.84/lightsSmall.jpg"/>
CUCM 8 Publisher node
Matt's lab in the UK NGN HCS cluster
83221735 / mabarber@cisco.com
I have an example image on my HTTP server, which this HTML IMG tag points to.
See the example output here:
Hope that helps you get your customer what they need. Maybe they will accept this rather than the top left logo change.
Matt
Good find Matt, thanks for sharing +5 for that.
Found a small caveat - if you log in via SSH then the HTML is spat out onto the console before the login.
--Matt
