01-19-2016 08:56 AM - edited 03-17-2019 05:33 AM
We moved our VG202's to a new building and they were previously set up by another company, we need to change the subnet in which they reside on. Can anyone give me a hand?
01-19-2016 09:30 AM
Refer to this doc which shall help you to configure the setting.
http://www.cisco.com/c/en/us/td/docs/routers/access/vg202_vg204/software/vg2_vg4_scg/vg2_vg4_conf.html#wp1039811
01-20-2016 01:14 PM
It depends on what protocol you are using to control the GW as to what needs to be done. Changing IP address on the GW is one thing, but then if you are using SIP/H323 you need to change reference of it in CUCM, etc.
