cheap system for 1 voip phone?
baselzind
Level 6
Level 6
is there a voip desk phone that can use a mobile carrier sim? or is there a cheap small system for 1 voip phone? the user just want to use a desk phone with a reachable number from outside.
7 Replies 7
balaji.bandi
You want SIP phone to use SIM card to register with SIP provider ? or SIP phone to use SIM card  to call ?
BB
I want SIP phone to use SIM card  to call like a normal mobile phone
A mobile phone call is, essentially, a SIP call.
Would work outside usa??? Like in the middle east
Unfortunately, these deskphones only work in USA.
You can check the link below for GSM based deskphone. The description says the the phone is compatible with any GSM SIM card. You may want to reach out the seller to double check if it works in your country.
https://www.amazon.com/BW-Wireless-Desk-Telephone-Especially/dp/B01HTEEE9W/ref=sr_1_3?crid=315BLZ0OZZLQ8&keywords=deskphone+with+sim+card&qid=1665766859&sprefix=deskphone+with+sim+card%2Caps%2C97&sr=8-3
You can also search for GSM based deskphones on google and see if you can any options in your location.
abhishekreve
Do you need a phone system? you can try Kloudtalk check the details here: https://www.kloudtalk.com/product/kloudtalk
