check call routing on voice gateway
suthomas1
Level 6
Level 6
Hello all,
Just thinking of a DR scenarion in terms of voice calls via our voice gateways.
We have 2 sites - one being the main site with more channel capacity & the other with
lesser capacity on our voice gateway routers/isdn.
what way to check if the calls are indeed flowing through the desired gateways? any help with commands will be great.
thanks in advance.
Flo.Matalis
I normally use below when SIP/H323.
show call active voice compact
voice call status
show isdn active
If MGCP, since calls are back-hauled to CUCM, I use "debug isdn q931" and check from the debugs.
Chris Deren
With PRI circuit as you allude to ISDN you can simply do:
show voice call summary
show voice port summary
